E1 WIC for Unframed
kvnmurthy
My E1 controller card is not supporting unframed E1 connection.My E1 card details are below mentioned.
E1 0/0 is down.
Applique type is Channelized E1 - balanced
Description: WAN INTERFACE
Far End Block Errors Detected
Receiver has loss of signal.
alarm-trigger is not set
Version info Firmware: 20040108, FPGA: 11
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 0.
Data in current interval (873 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 873 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 873 Unavail Secs
Data in Interval 1:
0 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
Data in Interval 2:
Data in Interval 3:
8 Replies 8
spremkumar
Level 9
Level 9
Hi Murthy
Can you confirm whether you have tried configuring channel-group 1 unframed under controller config ?
regds
I tried channel-group 0 unframed, but it is not supporting
Can you paste the output of show version and show diag here ?
regds
Sorry for the delay, here is the sh diag command output
show diag
Slot 0:
C2610XM 1FE Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 3.1
PCB Serial Number : FOC08290FRH (433153135)
Part Number : 73-7677-05
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : A0
Deviation Number : 0-0
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 6A 41 03 01 C1 17 46 4F 43 30 38 32
0x10: 39 30 46 52 48 20 28 34 33 33 31 35 33 31 33 35
0x20: 29 82 49 1D FD 05 04 00 81 00 00 00 00 42 41 30
0x30: 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- WIC Slot 0:
E1 (1 port) WAN daughter card
Hardware revision 1.0 Board revision F0
Serial number 32594159 Part number 800-04475-03
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 21 01 00 01 F1 58 EF 50 11 7B 03 00 00 00 00
0x30: 78 00 00 00 04 08 22 00 FF FF FF FF FF FF FF FF
Router#
Router#sh ver
IOS (tm) C2600 Software (C2600-IPBASE-M), Version 12.3(6c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 20-Jul-04 05:24 by kellythw
Image text-base: 0x80008098, data-base: 0x80ED06CC
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Router uptime is 7 minutes
System image file is "flash:c2600-ipbase-mz.123-6c.bin"
cisco 2610XM (MPC860P) processor (revision 0x301) with 126976K/4096K bytes of memory.
Processor board ID FOC08290FRH (433153135)
M860 processor: part number 5, mask 2
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
1 Channelized E1/PRI port(s)
--More-- 32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Router#
Is there any one to help in this regard?
rdessert
To configure it for unframed try this:
conf t
controller e1 0/0
no framing crc4
Hope this helps.
handoko.wiyanto
hi there,
as my understanding, you are trying to configure E1 as unframed, means for data, correct?
afaik, your e1 card must support g703 for unframed.
what e1 card are you using now?
