04-04-2006 09:03 PM - edited 03-03-2019 12:18 PM
I tried configuring E3 by dividing it into 16 channels and then multilinking. is there any way to configure it as single E3. One of my friends suggested 'no channelized' under controller e3. But it is not supported in the IOS. I am using Cisco 7609 with sup720 and IOS 12.2(17d)SXB6.
TIA
Solved! Go to Solution.
04-04-2006 09:17 PM
As far as i have known, there is no way to use ch.E3 as single E3. 16 E1s are preconfigured, you will see this when you give a "show controller E3". You have to use PA-E3 instead of PA-MC-E3.
Hope this helps
04-04-2006 09:17 PM
Hope this helps
04-04-2006 11:30 PM
Can you make it unframed and see if you can use it as a single E3 ?
04-05-2006 12:18 AM
These are the only commands available under controller e3
CR7609(config-controller)#?
Controller configuration commands:
clock Specify the clock source for an E3 interface
default Set a command to its defaults
description Controller specific description
e1 E1 line configuration
exit Exit from controller configuration mode
help Description of the interactive help system
idle Specify the idle pattern all channels on an E3 interface
loopback Put the entire E3 line into loopback
national Specify the national bit setting for an E3 interface
no Negate a command or set its defaults
shutdown Shut down an E3 interface (send Blue Alarm)
CR7609(config-controller)#no ?
