Easy Question Re: WIC-1DSU-T1
First Question: Is the device hot swappable? I would think so, but just wanted to make sure.
Second question: Can WIC-1DSU-T1 cards and WIC-1DSU-T1-V2 cards be used in the same router and in the same MLPP bundle, or do they all need to match (V2 vs. not V2) ?
Gold
Re: Easy Question Re: WIC-1DSU-T1
No you can't hot swap them. If you install them in something like a nm-2wic you can hot swap the who module including the wic but you cannot remove the wic card itself directly.
As long as the router supports both v1 and v2 cards they can run together the difference is related to physical cable support.
Thanks tdrais, so if not hot swappable, the entire router has to be powered down? The wic is in a NM-1e2w but the second wic is online and functioning properly so I don't want to affect that traffic if possible. My best case scenario will have to wait until a maint. window in that case if I have to distrub the other traffic on the router.
142
