Easy VPN client problem
itdsmartnet
hi, i have downloaded and installed easy vpn client "vpnclient-win-msi-5.0.03.0530-k9". The problem is that after some time may be one to two days, my LAN card stops working, when i remove the VPN client, then my LAN card starts working again. need help regarding this issue
8 Replies 8
andrew.prince
Level 10
Level 10
Try using the 4.8 version of client.
HTH>
i have already used client "Release_4.0.1" there is the same problem.
Then that would indicate not a client issue - but a hardware or OS issue. I would suggest you look in the area of a TCP stack issue.
HTH>
i have dell latituded d610 and i have installed on my desktop system too. The same problem occurs in desktop system too. When i issue the command "sh ipconfig/all" it shows nothing, but when i check the TCP/IP properties of network card there is an ip assigned to it. please help me in this matter.
post the debug from the Cisco VPN client - you need to set the lop setting levels as:-
IKE 3-high
User Auth 3-high
IPSEC 3-high
Firewall 3_high
how can i do these settings.
Open the VPN client - then from the menu choose "Log" then "log Settings" and change them - see attached for a screen shot. Once you have changed the settings, Open the "Log Window" then start a VPN session - you will see the output of the debug.
HTH>
