Silver
eBGP default 0.0.0.0 redistribution into OSPF
I know about def-info orig [always].
And aware too of stub/t-stubby/nssa rules.
My question is why does ospf deny the redistribution of external 0.0.0.0 into itself?
r1---ebgp---r2---ospf---r3
r2 has a 0.0.0.0 route present in it's rt learned via ebgp (20). r2 then attemtps to redist all bgp routes into ospf. it manages to accomplish this except the default.
Is there any workaround other than those listed at the top of this posting. I want to use the redistribution of bgp learnt 0.0.0.0 into ospf.
tia
Ajaz
1 ACCEPTED SOLUTION
Re: eBGP default 0.0.0.0 redistribution into OSPF
Hi Ajaz,
EIGRP is the only routing protocol that doesn't utilize the default-information originate command , to advertise default information just do the redistribution.
BR,
Mohammed Mahmoud.
Ajaz,
The only way to inject the default route in OSPF is, as you mentioned, through the "default-information originate" command. Redistribution of the default from another source is explicitly prevented by IOS.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Silver
Cool man. What's the score with eigrp then - same?
Hi Ajaz,
BR,
Mohammed Mahmoud.
Silver
Much appreciated Mohammed.
case closed :-)
asa - ajaz
181
