ECC Messages appear at 7206 VXR console
Dear Group,
We have a 7206VXR Router in which we are facing problem that sometimes router doesn't forward authentication request to AAA and a message appear " %BCM-4-ECC_MEMORY: Corrected ECC from memory ".
Mujeeb
  • WAN Routing and Switching
1 ACCEPTED SOLUTION
Silver
Re: ECC Messages appear at 7206 VXR console
Hi Mujeeb,
Can check whether there are any ECC errors using following command .
config)# show sysctlr .
ex:B11DATACENTERR2#show sysctlr
BCM1250 LDT Host Bridge, handle=0
BCM bridge, config=0x0
(0x00):dev, vendor id = 0x0002166D
(0x04):status, command = 0x00100107
(0x08):class code, revid = 0x06000002
(0x0C):hdr, lat timer, cls = 0x00010000
(0x18):bus id registers = 0x000F0300
(0x1C):secondary status = 0x0000F141
(0x20):mem base/limit = 0x4FF04880
(0x30):io upper limit/base = 0x00010001
(0x34):capabilities ptr = 0x00000040
(0x38):expansion rom bar = 0x00000000
(0x3C):bridge ctrl = 0x00220000
(0x40):LDT cmd, cap id, = 0x20000008
(0x44):Link config/control = 0x00000020
(0x48):Link frequency = 0x00000211
(0x50):SRIcmd, srirxden, sritxden = 0x52211010
(0x54):SRI tx numerator = 0x0000FFFF
(0x58):SRI rx numerator = 0x0000FFFF
(0x68):Error status/control = 0x00009A49
(0x6C):Tx ctrl, databufalloc = 0x00041515
(0xC8):Tx buffer count max = 0x00FFFFFF
(0xDC):Rx CRC expected = 0xFF7FDFFF
--More-- (0xF0):Rx CRC received = 0xFFF7EAFA
BCM PCI Host Bridge:
bus_no=0, device_no=0
DeviceID=0x0001, VendorID=0x166D, Cmd=0x0146, Status=0x02A0
Cls=0x06/0x00/0x00, Rev=0x02, LatencyTimer=0x2C, CacheLineSize=0x10
BaseAddr0=0x60000008, BaseAddr1=0x00000000, MaxLat=0x00, MinGnt=0x00
SubsysDeviceID=0x0000, SubsysVendorID=0xFFFF, ErrorAddr=0x00000032
Bus Watcher Counters
cor_l2cache_data_ecc_count = 0
bad_l2cache_data_ecc_count = 0
cor_l2cache_tag_ecc_count = 0
bad_l2cache_tag_ecc_count = 0
cor_memory_data_ecc_count = 20 <<<<<<<<<<<<<<--- Here You Find The ECC Count
bad_memory_data_ecc_count = 0
bus_errors = 0
BCM Status Registers
A_SCD_BUS_ERR_STATUS = 0000000080000000
A_BUS_ERR_DATA_0 = FFFFFFFFFFFFFFFF
A_BUS_ERR_DATA_1 = FFFFFFFFFFFFFFFF
A_BUS_ERR_DATA_2 = FFFFFFFFFFFFFFFF
A_BUS_ERR_DATA_3 = FFFFFFFFFFFFFFFF
A_SCD_SYSTEM_REVISION = 6F496025125011FF
A_IO_INTERRUPT_STATUS = 0000000000000000
A_IO_INTERRUPT_ADDR0 = 0000000000000000
A_IO_INTERRUPT_ADDR1 = 0000000000000000
If you see ECC errors then the problem is related to a hardware problem. The EEC messages comes, when the system can recognize faulty data in the SDRAM.
*****I suggest you to RMA your NPE card.
****If you are not seeing any ECC errors then workaround is The IOS upgrade and the reseat of the DRAM was a very good idea.
Hope it helps you.Plz rate it....
satish
Silver
Hi Mujeeb,
bus_errors = 0
satish
Dear Satish,
Thanks for your support , problem is resolved after replacement of NPE card.
Mujeeb
Blue
it seems your memory may have problems and may need to be replaced
replace the memory and verify if the symptoms persist.
if the problems persist, there may be an issue with the system board and the repair/replacement of the router will be required.
please see the following link for more info on this error: (second message down)
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_system_message_guide_chapter09186a00801eb2bc.html#wp771222
Dear gpulos,
Thank you very much for your support , problem is resolved after replacement of NPE card. The link you have given in your previous is very informative and will be very helpful in future to troubleshoot hardware related issues.
Mujeeb
855
