03-17-2012 05:15 AM - edited 03-04-2019 03:42 PM
hi,
i have a question regarding egress queuing on cat6500 modules. e.g. WS-X 6704 has 1p7q4t is egress-modell. my goal is to limit the priority queue to 15% of the available bandwidth.
i can put weights on the wrr-queues and limit their ressources: "wrr-queue bandwidth 50 20 15 0 0 0 0." but this isn´t possible for the priority-queue. only available command is "priority-queue queue-limit 15" but this only restricts the buffer to 15%.
at the end of the day i want to prevent that the wrr-queues don´t have remaining bandwidth when the priority-queue is saturated.
is there an easy way to restrict the bandwidth of the priority queue or do i have to implement additionally some kind of policing?
thx
03-17-2012 05:59 AM
allocate bandwidth to other queues as you did and leave 15% which will be used by the PQ
03-17-2012 06:36 AM
but what happens in thois case if i have 10Gig traffic which is marked with EF. in this case everything is transported in the priority queue and all other queues don´t have any bandwidth. is my assumption correct or do i understand something wrong?
03-17-2012 05:41 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe the "typical" LAN 6500 line card will allow a PQ queue to utilize 100% bandwidth.
For traffic that uses "EF", it ought to be known and subject to admission control. If this is done, you shouldn't unexpectedly have EF traffic consume all your 10gig bandwidth.
03-17-2012 06:07 PM
Yes Joseph right the PQ always serviced first and could take over other classes bandwidth
If you really have concern about it
The in inbound direction use a policed to police traffic marked with dscp ef to a specified amount
And the higher amount could be marked down instead if drop it
03-18-2012 06:01 AM
thanky ou very much. that´s what i wanted to know
