EHWIC-4G, BGP/MPLS VPN, and IPSEC
Any ideas on how the following might be accomplished? I've been mocking up configurations with no success:
Branch network is 172.30.38.0/24... networks 192.168.123.0/24 and 172.30.31.0/24 are brought in through BGP, over an MPLS VPN... but I'd like to block inbound distribution of those networks and route them into an IPsec tunnel, through an EHWIC-4G-LTE-V (Verizon), which will peer with a router that has 192.168.123.0/24 as its LAN.
Every time I apply the crypto map to my cellular interface, it starts bouncing, and IPsec debugging repeatedly shows "Kicking dialer interface".
I'll happily provide my latest configuration attempt, if needed. Thanks!
Re: EHWIC-4G, BGP/MPLS VPN, and IPSEC
Hello, Jeremy.
Is it possible to share your current configuration (interfaces c0/0/0, dialer, MPLS CE interface, static routes, crypto map)?
PS: is it possible to convert crypto map into VTI?
I'll definitely give VTI a try.
Here's the latest configuration I've tested:
Version 15.3
crypto isakmp policy 10
     encr aes
     authentication pre-share
     group 2
     lifetime 28800
crypto isakmp key ******** address *.*.*.* no-xauth
crypto isakmp profile AGGRESSIVE
     self-identity fqdn ROUTER
     match identity address *.*.*.* 255.255.255.255
     initiate mode agressive
crypto ipsec transform-set SET esp-aes esp-sha-hmac
     mode tunnel
crypto map MAP isakmp-profile AGGRESSIVE
crypto map MAP 10 ipsec-isakmp
     set peer *.*.*.*
     set transform-set SET
     set pfs group2
     match address 101
interface Cellular0/0/0
     ip address negotiated
     ip nat outside
     ip virtual-reassembly in
     encapsulation slip
     dialer in-band
     dialer idle-timeout 0
     dialer string lte
     dialer-group 1
     async mode interactive
router bgp *****
     bgp log-neighbor-changes
     network 192.168.51.0 mask 255.255.255.0
     neighbor *.*.*.* remote-as *****
     neighbor *.*.*.* distribute-list 2 in
ip nat inside source list NONAT interface Cellular0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
ip access-list extended NONAT
     deny ip 192.168.122.0 0.0.0.255 172.30.31.0 0.0.0.255
     deny ip 192.168.122.0 0.0.0.255 192.168.123.0 0.0.0.255
     permit ip any any
dialer-list 1 protocol ip permit
access-list 2 deny 192.168.123.0 0.0.0.255
access-list 2 permit any
access-list 101 permit ip 192.168.122.0 0.0.0.255 172.30.31.0 0.0.0.255
access-list 101 permit ip 172.30.31.0 0.0.0.255 192.168.122.0 0.0.0.255
access-list 101 permit ip 192.168.122.0 0.0.0.255 192.168.123.0 0.0.0.255
access-list 101 permit ip 192.168.123.0 0.0.0.255 192.168.122.0 0.0.0.255
line 0/0/0
     script dialer lte
     modem InOut
     no exec
Thanks for your time!
Hello, Jeremy.
Definitely VTI could help you. But here some notes:
  • you are using strange ACL 101 (it should describe only traffic originated on your site, but not backtrack traffic);
  • I would configure 4G via Dialer interface (see deployment guide for details -
http://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Aug2013/CVD-VPNRemoteSiteOver3G4GDesignGuide-AUG13.pdf). And actually this could be a cause.
277
