EIGRP - 2600 and 3640
I am trying to enable EIGRP on both my 2600 and 3640, but I keep getting :
IP-EIGRP(Default-IP-Routing-Table:1): Neighbor 192.168.2.1 not on common subnet for Ethernet0/0
on the 2600....
Help please:
2600 Show Run:
Current configuration : 973 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname Router
boot-start-marker
boot system flash
boot-end-marker
no logging on
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.3.1 192.168.3.150
ip dhcp pool 192.168.3.0/24
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   dns-server 192.168.2.127 192.168.2.128 8.8.8.8
username woodjl1650 privilege 15 password 0 henry999
interface Ethernet0/0
ip address 192.168.3.1 255.255.255.0
half-duplex
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
router eigrp 1
network 192.168.0.0
network 192.168.2.0
network 192.168.3.0
auto-summary
no ip http server
ip classless
snmp-server community public RO
snmp-server community private RW
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
end
3640 Router:
Current configuration : 1872 bytes
version 12.2
hostname 3640-Internet
boot system flash c3640-ik9s-mz.122-40a.bin
memory-size iomem 25
ip subnet-zero
ip cef
ip domain-name www.jkkcc.com
ip name-server 192.168.2.127
ip name-server 192.168.2.128
ip dhcp excluded-address 192.168.2.1 192.168.2.150
ip dhcp pool 192.168.2.0/24
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 192.168.2.127 192.168.2.128 8.8.8.8 127.0.0.1
call rsvp-sync
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Ethernet1/0
no ip address
shutdown
half-duplex
interface Ethernet1/1
no ip address
shutdown
half-duplex
interface Ethernet3/0
no ip address
shutdown
half-duplex
interface Ethernet3/1
no ip address
shutdown
half-duplex
router eigrp 1
network 192.168.0.0
network 192.168.2.0
network 192.168.3.0
auto-summary
ip nat inside source list 15 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.2.128 80 interface FastEthernet0/0 80
ip nat inside source static tcp 192.168.2.128 25 interface FastEthernet0/0 25
ip classless
ip http server
ip http authentication local
access-list 15 permit 192.168.2.0 0.0.0.255
snmp-server enable traps tty
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
1 ACCEPTED SOLUTION
Purple
no it won't form a neighbour relationship.
Regards.
Alain
As you mentioned there is IP address on the point to point link are not in same subnet.Change the subnet IP address either on e0/0 OR f0/1.
ip address 192.168.3.1 255.255.255.0 <<<<<
half-duplex
ip address 192.168.2.1 255.255.255.0 <<<
So EIGRP does not work on two different subnets?
Purple
Regards.
Alain
390
