EIGRP contingency
hello.
there is a router run eigrp and ospf, and when redistribute from eigrp to ospf, only route learned from other neighbors, which mean didn't redistribute its own route ( directly connected ), could somebody explain what kind of situation is this ? configuration was really simple. no filtering no route-map, just has a passive-interface, but when get that way, still same situation.
Re: EIGRP contingency
Do you have your connected interfaces IP covered under the n/w command in the EIGRP AS. Do you have router condifgured as EIGRP STUB router.
It will be handy to see the config of your router.
regards,
-amit singh
with configuration as below,,, 2.2.2.2/24 and 2.2.14.0/24 is not show on the ospf side....
without passive default, same result
interface Loopback0
ip address 2.2.2.2 255.255.255.0
interface FastEthernet0/0
ip address 2.2.14.2 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 2.2.235.2 255.255.255.0
encapsulation frame-relay
ip ospf message-digest-key 1 md5 cisco
ip ospf priority 0
no fair-queue
frame-relay map ip 2.2.235.3 203 broadcast
frame-relay map ip 2.2.235.5 205 broadcast
no frame-relay inverse-arp
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router eigrp 2
redistribute ospf 1 metric 10000000 1000 255 1 1500
passive-interface default
no passive-interface FastEthernet0/0
network 2.2.2.2 0.0.0.0
network 2.2.14.2 0.0.0.0
no auto-summary
router ospf 1
router-id 2.2.2.2
log-adjacency-changes
area 0 authentication message-digest
redistribute eigrp 2 metric 100 subnets
redistribute connected metric 200 subnets route-map con
network 2.2.235.2 0.0.0.0 area 0
distance 171 0.0.0.0 255.255.255.255
ip http server
ip classless
Bronze
You need to add those to the OSPF configuration. You cannot pull this into EIGRP and than to OSPF because they are on the same router. EIGRP will only redistribute what it learns from it's neighbors.
So you would need to add this to your ospf configuration.
network 2.2.2.2 0.0.0.0 area x
network 2.2.14.0 0.0.0.255 area x
Daniel
114
