Community Member
EIGRP default-information
Have read ciso documentation many times but still not able to understand the command "default-information". Can someone show me the example?
many thanks
Community Member
Re: EIGRP default-information
Hi there,
"Whenever you use the redistribute or the default-information router configuration command to redistribute routes into an OSPF routing domain, the Cisco IOS software automatically becomes an Autonomous System Boundary Router (ASBR)."
or
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_command_reference_chapter09186a00800917e6.html#wp1025098
hope that helps
sometimes it is nessessary to generate a default route (0.0.0.0/0) for a network. An example would be a BGP router connected to the internet will not insert the whole internet routing table into OSPF but preferably a default route. The question is how to achieve this.
One option is f.e. through OSPF:
router ospf 10
default-information originate always
This will tell this router to generate a default route for the rest of the OSPF network. All traffic to the internet will follow the default route to the internet gateway and there you send the traffic to the prefered ISP, and so on.
Hope this helps! PLease rate all posts.
Regards, Martin
Community Member
I think everyone missed the EIGRP in the title :)
The default-information command is left over from IGRP. IGRP couldn't directly handle 0.0.0.0/0.
Are you looking to implement EIGRP and have a specific question about default routing, or were you just curious about the command?
555
