EIGRP default-network propagation
hallo
I have a doubt about the propagation of the default-network by a router running eigrp (in classless mode) to other routers in the same eigrp as.
Is it true that the default-network will be announced only if:
1) the router has an interface UP in that network, and
2) that network is a major network or the subnet-zero, and
3) that network is in the network statements under eigrp process.
OR
1) the defined default-network in router config will be learned through another eigrp router in the same as, and
2) that network is in the network statements under eigrp process.
for example if I have:
ROUTER-A)
interface f0/0
ip address 192.168.1.20 255.255.255.240
interface s0/0
ip address 172.16.1.1 255.255.255.252
clock rate 128000
router eigrp 100
network 192.168.1.0
network 172.16.0.0
no auto-summary
ip default-network 192.168.1.0
ip route 0.0.0.0 0.0.0.0 192.168.1.27
ROUTER A does not announce the subnet 192.168.1.16/28 as default D*
BUT IF I HAVE:
interface f0/0
ip address 192.168.1.1 255.255.255.240
interface s0/0
clock rate 128000
router eigrp 100
network 192.168.1.0
network 172.16.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 192.168.1.5
THE ROUTER WILL PROPAGATE 192.168.1.0/28 as D*
Could you help me ?
best regards
francesco
Hall of Fame Super Bronze
Re: EIGRP default-network propagation
Let's verify eigrp was enabled on that interface on the first example.
Please post the output from typing
show ip proto and show ip eigrp int
hi Edison,
I attached a txt file with a simple test network layout and the results for the show commands you requested.
At the moment I can't use serial intefaces, so I used routers with two fastethernet, it's the same thing.
thankyou
francesco
Not sure why D* is so important to you vs just D, but in order to have a D* you need to have an ip default network command in Router B.
For instance, if you remove this command from Router A
The D* reference will become D.
HTH,
Hi Edison,
Router A is attached on a LAN tha know a def. gateway 192.168.1.27, but that gateway does not announce a default-network.
So I want Router A to announce the default network to other routers like Router B.
D* eigrp routes allow to rotate pachets that does not have other route matches in routing table, without inserting static routes like 0.0.0.0/0.
If you try to modify the Router A config, using the 192.168.1.0/28 (like in folowing config) and not the 192.168.1.16/28 subnet, on Router B you will see the 192.168.1.0/28 with D* !
ROUTER-A#sh run
Building configuration...
Current configuration : 964 bytes
version 12.3
hostname ROUTER-A
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
no ip domain lookup
no ftp-server write-enable
no crypto isakmp ccm
interface FastEthernet0/0
!ip address 192.168.1.20 255.255.255.240
duplex auto
speed auto
interface FastEthernet0/1
description TO-ROUTER-B
duplex auto
speed auto
router eigrp 100
network 172.16.0.0
network 192.168.1.0
no auto-summary
ip classless
!ip route 0.0.0.0 0.0.0.0 192.168.1.27
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
I wish to know why eigrp with the previous config announces a D* while using 192.168.1.16/28 this not happens !
To have D* networks on routers not directly connected to def-gateways, working in every situation, must I config "ip default network x.y.z.t" on that routers and leave the router directly connected to x.y.z.t subnet simply announing x.y.z.t through eigrp without the command "ip default network x.y.z.t" ?
Is this what you want to tell me ?
thankyou best regards
francesco
If you want to announce a default gateway, the best approach is:
Router A
ip route 0.0.0.0 0.0.0.0 [default gateway]
router eigrp x
redistribute static metric 1 1 1 1 1
HTH,
yes
but if you have other static routes other than the 0.0.0.0/0 the "redistribute static" redistribute all static routes !
I don't want redistribute all static routes !
It could be useful have a loopback interface with an ip address in a subnet-zero,like following ?
interface loopback 0
ip address 192.168.5.1 255.255.255.252
router eigrp 100
network ....
network 192.168.5.0
no auto-summary
ip default-network 192.168.5.0
ip route 0.0.0.0 0.0.0.0 def-gateway
francesco
In that case, you can redistribute through a prefix-list so you can control what gets redistributed.
ip prefix-list static->eigrp permit 0.0.0.0/0
route-map static->eigrp permit 10
 match ip address prefix static->eigrp
 set metric 10000 100 255 1 1500
router eigrp
 redistribute static route-map static->eigrp
You can add prefixes to the prefix-list as many as you want.
Kevin Dorrell
Luxembourg
hi Kevin,
prefix-list could be a solution
not simple but a solution...
but at the moment noone said why EIGRP announces 192.168.1.0/28 like D* and 192.168.1.16/28 like D...
why this behaviour difference ?
best regards
francesco
Francesco,
I addressed this topic days ago. The D* is due to the ip default-network statement you have in the router. If you remove the ip default-network statement, the * after the D will go away.
If you issue a show ip route and look at the legend in the top, it explains what the "*" is for.
BTW, this command is classful so even if you input 'default-network 192.168.1.16' it will automatically change it to 192.168.1.0.
HTH,
excuse me Edison,
but I want to be sure to understand the concept !
The last questions
1) you said "The D* is due to the ip default-network statement you have in the router".
The router that receive the network or announce the network "adds the *" or both ?
2) you said "BTW, this command is classful".
But the eigrp runs in classless mode with "no autosummary" !
3) If I don't have "ip default-network" on the router B that receive the network, and the router A that announce the network has "ip default-network 192.168.1.0" and interface address
192.168.1.20/28 -> on B I don't have D*
192.168.1.1/28 -> on B I have D*
It's only due to the classful property of "ip default-network command " ?
thanks
best regards
francesco
1) Yes, remove it and you will see the neighbors not having the "*" after the D.
The router that announces the network adds the D*.
2) ip default-network is not EIGRP. EIGRP uses that information for advertisement.
3) Yes, the classful property is due to the command in itself, not the underlying routing protocol. Try typing 192.168.1.20 on the ip default-network, it will automatically change to 192.168.1.0 ...
HTH,
thankyou Edison
francesco
1308
