Webcast-Catalyst9k
EIGRP default route?
I have 64 locations running EIGRP, how do I advertise a default-route into EIGRP that all locations will learn? We have a single Internet T3 at one location where I want to advertise the default route to other locations.
In OSPF I do a;
router ospf 100
default-information-originate
1 REPLY
Hall of Fame Super Gold
Re: EIGRP default route?
There are several alternatives that would work. Perhaps the most simple is to configure a static default route pointing out the T3 and redistribute the static default into EIGRP. The router on which it is redistributed will advertise it to all its neighbors and it will propagate through the network. You could also configure the default network command.
Rick
278
