07-06-2006 07:17 PM - edited 03-03-2019 01:15 PM
I have 3 routers in the same LAN, say R1(10.1.1.1),R2(10.1.1.2) and R3(10.1.1.3), they are running EIGRP now, how do let r1 and r2 communication each other tp form a eigrp neighbor without send any eigrp related packet to r3?
07-06-2006 10:12 PM
One thing you could do is to use the neighbor statement under the EIGRP process on R1 and R2:
R1:
router eigrp 100
neighbor 10.1.1.2
R2:
router eigrp 100
neighbor 10.1.1.1
Hope that helps - pls do rate the post if it does.
Paresh
07-06-2006 10:54 PM
thanks for your reply. please look at my example:
R1(router)--------R2(Cat 3750 with lay3 enabled)----R3
r1:
router eigrp
network 12.12.12.0
r2:
int vlan 1
ip addr 12.12.12.2 255.255.255.0
router eigrp 10
network 12.12.12.0
neighbor 12.12.12.1 vlan 1 (define the r1 neighbor)
r3:
router eigrp 10
network 12.12.12.0
but from the r2, I show ip eigrp neighbor, not any neighbor can be seen. If I remove the "neighbor" command, I saw 2 neighbors.
07-06-2006 11:01 PM
by the way, are there any ways to implement this except "neighbor"?
07-06-2006 11:56 PM
"if you want the outgoing routing updates alone be suppressed but the inbound updates continue to be received (and the routers still continue to be neighbors), then use the distribute-list command"
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f0a.shtml
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080208748.shtml
a 'distribute-list' in on R3, with sources R1/R2 denied?
Andrea
07-07-2006 06:49 AM
it is not routing update issue, I even don't want them to form eigrp neighbor even they are runnig the same eigrp and in the same AS.
07-07-2006 07:19 AM
Hi, perhaps make the interface to R3 passive.
07-07-2006 07:54 AM
Yep, use passive interface on R3
Andrea
