Webcast-Catalyst9k
EIGRP flapping
EIGRP gettig due to bad checksum error. What would be possible solution for bad checksum error.
Hall of Fame Super Gold
Re: EIGRP flapping
sampath
I would assume that a bad checksum might be caused by physical layer errors in transmission. Can you check the physical media for problems?
Rick
Re: EIGRP flapping
i have check interface parameters that is observed any link errors. i am getting EIGRP: bad checksum from x.x.x.x when debugging. This leads to eigrp flapping frequently.
Re: EIGRP flapping
Hi ,
The could be 2 reason for this
1.link issue
2.Bug
Chao
Vishwa
303
