Webcast-Catalyst9k
EIGRP - Frame-relay Broadcast Queue
After a IOS upgrade on 7206VXR, the remote sites do not learn routes. I got eigrp how my routing protocol.
I think we have an issue related with frame-relay broadcast queue but i do not understand how to set the parameters of frame-relay broadcast queue command.
Speed link: E3 (34010 Mbps)
# DLCI: 105
Thanks in advance.
1 REPLY
Re: EIGRP - Frame-relay Broadcast Queue
Hello Julio,
How exactly did you come to the idea that you have problems with Frame Relay broadcast queue? Regarding your defunct EIGRP, what exactly seems to be the problem? Do your routers at least see themselves as neighbors? (Use the "sh ip eigrp nei" command for that.) If yes, are there any networks placed in the EIGRP topology table - "show ip eigrp topology"?
Best regards,
Peter
104
