12-28-2009 12:24 PM - edited 03-04-2019 07:04 AM
EIGRP metric calculation?
I have a 6513 with EIGRP routing protocol.
When I try to calculate the EIGRP metric of a interface loopback 0, using the
bandwidth value and delay value that show interface loopback 0 command.
es-plcdatacenter2#sh int loo
es-plcdatacenter2#sh int loopback 0
Loopback0 is up, line protocol is up
Hardware is Loopback
Internet address is 172.16.3.36/32
MTU 1514 bytes, BW 8000000 Kbit, DLY 5000 usec,
Encapsulation LOOPBACK, loopback not set
Last input 00:00:02, output never, output hang never
Last clearing of "show interface" counters 1w3d
Queueing strategy: fifo
Output queue: 0/0 (size/max)
L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
189839 packets output, 11390340 bytes, 0 underruns
es-plcdatacenter2#
es-plcdatacenter2#
but when I was used the "SHOW IP EIGRP TOP x.x.x.x/x" command, I see the next information "Minimum bandwidth is 10000000 Kbit"
What about that?
In this link http://ccie-en-espanol.blogspot.com/2009/05/eigrp-mtu-y-metrica.html#comment-form
I found the following information:
Some default values for Bandwidth and Delay associate to some interfaces type are listen on the next table
Media.........Bandwidth..Delay
FastEthernet...100000K...100µS
Ethernet........10000K...1000µS
T1..............1544K....20000µS
DS0..............64K....20000µS
56K..............56K....20000µS
es-plcdatacenter2#
es-plcdatacenter2#sh ip eigrp top 172.16.3.36/32
IP-EIGRP (AS 4944): Topology entry for 172.16.3.36/32
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 128256
Routing Descriptor Blocks:
0.0.0.0 (Loopback0), from Connected, Send flag is 0x0
Composite metric is (128256/0), Route is Internal
Vector metric:
Total delay is 5000 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1514
Hop count is 0
I will apreciate some assistance about that.
David Salazar
Solved! Go to Solution.
12-28-2009 01:14 PM
Hello David,
I would say it is a resolution problem.
With effective settings the contribute of BW to metric is : (10^7 / 8000000)*256 = 1.25 *256
the metric is calculated taken the truncated version of 1.25 = 1
you see metric as 128256 = 500*256 + 256*1
using 1,25 it would be: 500*256+1,25*256 = 128320
then the sh ip eigrp topology expands the metric in the two components giving 5000 microseconds and 10000000 kbps
Hope to help
Giuseppe
12-28-2009 02:29 PM
nando02 wrote:
Giuseppe
Thank a lot, for your valuable information.
Can you give me a technical reference where it is define the use of truncated method for EIGRP metric calculation?
I was thinking about the use of this method before writing on the Cisco Support Community but I do not find technical reference. I tried to remeber that I was read about it long time ago but I don't have writing reference.
Every time that division result in numerical fractional is used truncated method?
David
From the EIGRP whitepaper section on metric calculation -
Cisco routers do not perform floating point math, so at each stage in the calculation, you need to round down to the nearest integer to properly calculate the metrics
Full link -
Jon
12-28-2009 01:14 PM
Hello David,
Hope to help
Giuseppe
12-28-2009 01:59 PM
Giuseppe
12-28-2009 02:29 PM
nando02 wrote:
Giuseppe
David
Full link -
Jon
12-28-2009 08:59 PM
Thank a lot, Jon.
