Eigrp Neighbouring problem
adowfille
Im setting up a remote site connectivity to HQ using 2- ATM links. After configuring as per the attached , the two routers are not forming eigrp neighbour Relation.
I can ping 224.0.0.10 from both routers using their respective interface Ip addresses and the setup is working with static routes.
'Show ip eigrp interface' output indicates eigrp is enabled on the interfaces but with Zero count under peer entry.
Ive tried with disabling split horizon under the individual sub-interfaces but no luck.
Any help highly appreciated.
10 Replies 10
Kevin Dorrell
Level 10
Level 10
Under your eigrp, you need network 192.168.1.0 and network 192.168.2.0. 192.168.x.0 are class C networks, so the network 192.168.0.0 will not cover your interfaces.
I am surprised if show ip eigrp interface shows your WAN links.
Kevin Dorrell
Luxembourg
Kevin,
Thanks for your kind response. However sorry I missed out the mask settings on the posted configs. The actual configs used includes the correct mask as bellow:
router eigrp 60
network 192.168.0.0 0.0.0.255
network 10.1.10.0 0.0.0.255
Anything else that I may have missed-out?
Rgds
That is exactly what I mean. network 192.168.0.0 0.0.0.255 will not cover any of your WAN interfaces on R1. It will only cover interfaces whose addresses lie in the range 192.168.0.x. Your interfaces on R1 are in the 192.168.1.x and 192.168.2.x, so they are not covered.
Kevin Dorrell
Luxembourg
Kevin,
Thanks for your kind response and time. I ve updated the entries as follows but still no change
network 192.168.1.0 0.0.0.255
network 192.168.2.0 0.0.0.255
Rgds
Could you please post a show ip eigrp interfaces detail for each router?
If it were OSPF, I would be checking the adjacency timers are the same on both sides, but EIGRP does not have that constraint.
One thing I do notice is that on the .20 interfaces, both routers have the same IP address. You will need to correct that too.
Another thing you could try is to define static neighbors on each side. I don't know too much about ATM, but I do know it has issues with broadcasts.
Kevin Dorrell
Luxembourg
Kevin,
Thanks for your response.Ive actually shutdown interface .20 for now as I try to resolve the peering issue. Ive done similar implementation on ATM /FR without Dot1q taging or sub-interface and it is working fine.
Outputs are as follow:
IP-EIGRP interfaces for process 60
Xmit Queue Mean Pacing Time Multicast Pending
Interface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes
Fa0/0.10 0 0/0 0 0/10 0 0
Fa0/0.20 0 0/0 0 0/10 0 0
Show ip eigrp interfaces detail output:
Hello interval is 5 sec
Next xmit serial
Un/reliable mcasts: 0/0 Un/reliable ucasts: 0/0
Mcast exceptions: 0 CR packets: 0 ACKs suppressed: 0
Retransmissions sent: 0 Out-of-sequence rcvd: 0
Authentication mode is not set
Next xmit serial
Router R2:
AT1/0.10 1 0/0 0 16/608 608 0
Next xmit serial
Un/reliable mcasts: 0/0 Un/reliable ucasts: 0/9402889
Retransmissions sent: 8849745 Out-of-sequence rcvd: 0
AT2/1.20 1 0/0 0 16/608 608 5
Next xmit serial 255091
Un/reliable mcasts: 0/0 Un/reliable ucasts: 0/9402934
Retransmissions sent: 8849793 Out-of-sequence rcvd: 0
Ive already tried the static neighbour entries with no luck.
Rgds
Mm, I don't see any Hello interval on the ATM side. If you put a static neighbor on R2, does the Hello interval show up?
Kevin Dorrell
Luxembourg
Giuseppe Larosa
Hello Adow,
addition to what Kevin has already observed I would mind about different EIGRP timers:
on one side you have LAN subinterfaces
on the other side you have NBMA ATM interfaces and subinterfaces.
EIGRP will use the usual 5/15 seconds on the LAN but if your ATM interface are T1 or less default timers on the other side are different : 60/180
But actually this is not a problem with EIGRP.
have you added network 192.168.1.0 and network 192.168.2.0 on both routers
under router eigrp 60 ?
Hope to help
Giuseppe
Hello Kevin/Giuseppe,
Thank you for sacrificing your valuable time in assisting out.
I ve done static neighbour on both routers and still no change. I believe this has to do with the dot1q tagging/subinterface on R1 since Ive a 3rd site that is also terminating on R2 via ATM without any issues. The only difference is 3rd Site connectivity is via one primary link and there is no sub-interface /tagging configured.
Hello Adow,
just a last thought : you have LAN subifs on one side doing IPv4/Ethernet frames and ATM interfaces on the other side configured for AAL5SNAP IPv4/LLCSNAP/AAL5.
I suppose there is some device in the middle that performs a translation otherwise how could they talk ?
If your hyphotesis is correct you can try to do the following:
declare one of vlan 10,20 as native in order to have untagged frames out or R1
enc dot1q10 native
and you see if this changes something on the first link.
Check also if the atm subifs are up with sh atm pvc on R2.
Hope to help
Giuseppe
