Eigrp query
Q:-- which three of the following terms are known as reliable packets in EIGRP ??
A.) Hello
B.) ACK
C.) Reply
D.)Query
E.)Update
choose three..
1 ACCEPTED SOLUTION
Gold
Re: Eigrp query
That's another trick.... :-)
Ack's are nothing but any other packet with an extra TLV containing the sequence number of the packet being acknowledged, and the ack bit set in the packet header. So, an ack _could_ be reliable, if the ack is contained in an update, which does happen from time to time. But, when you ack a packet, you're never acking receiving the ack, but rather you're acking the other information that might happen to be in the packet.
In fact, we use this specific concept at startup to prevent unidirectional neighbor relationships from being formed. When an EIGRP router received a hello from another router, it will put the new neighbor in "pending" state, and send a unicast empty update. The new neighbor will then ack, but the ack must be contained in an update as well, so the ack is "reliable." After this, the new neighbor will be placed in its normal state, and topology tables will be exchanged, etc.
So, it can go both ways, but we normally don't consider ack's to be reliable, in terms of a test, etc.
Russ
Purple
Re: Eigrp query
The three packets that are sent reliably are:
C. Reply
D. Query
E. Update
Hope that helps - pls rate the post if it does.
Paresh
Re: Eigrp query
Reply,Query,Update are reliable packets in EGIRP.
Hello and ACK are not.
Gopal
Gold
Re: Eigrp query
Trick question! No fair! :-) There are actually four packet types that are reliable in EIGRP, but if this is from a test, I doubt the test has been updated to reflect the fourth type, which is an SIA-Query.
Russ.W
Purple
Re: Eigrp query
Hey Russ,
How about the Request packet ? Was that ever implemented ?
Paresh
Gold
Re: Eigrp query
I know we have some test capabilities, but I don't know if any of them actually use the request or probe packets.
Russ
Silver
Re: Eigrp query
What Russ hasn't mentioned here is that he has written a fantastic article on EIGRP in the latest edition of Packet Magazine.
I encrourage everyone to read it:
http://www.cisco.com/web/about/ac123/ac114/ac173/Q1-06/p_15.html
Thanks Russ.
Respectfully,
Brad
Re: Eigrp query
Hi all
Thanks for ur reply...
According to me reply,query & update packets are reliable..
Acknowledgement packets are also reliable in some cases.
Mahi
Gold
Re: Eigrp query
Russ
Re: Eigrp query
Thanks Russ...
You explained the concept very well...
Thanks a lot..
Mahi
247
