EIGRP redistribute into BGP not seeing routes in routing table
I am unable to see routes in the routing when distributing EIGRP routes into BGP. When doing a show ip bgp.. I do see the route listed, but not from the routing table. Attached is my network topology. How my lab is setup is that from DENTST Router to Cadiz-Rtr it is setup for BGP. From Cadiz-Rtr to CadizPlant-Rtr is setup for EIGRP. Cadiz-Rtr will be the one redistributing eigrp into bgp and bgp into eigrp. Here is the sh ip route output:
Cadiz-Rtr#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        1.1.1.0/30 is directly connected, Serial2/1.200
L        1.1.1.2/32 is directly connected, Serial2/1.200
      10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
D        10.168.192.0/24
           [90/409600] via 192.168.203.2, 09:26:43, Ethernet0/2.300
C        10.168.236.0/24 is directly connected, Ethernet0/0.2
L        10.168.236.254/32 is directly connected, Ethernet0/0.2
B        10.168.250.192/26 [200/0] via 1.1.1.1, 05:32:00
      172.16.0.0/24 is subnetted, 1 subnets
D        172.16.192.0 [90/409600] via 192.168.203.2, 09:26:43, Ethernet0/2.300
      192.168.203.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.203.0/30 is directly connected, Ethernet0/2.300
L        192.168.203.1/32 is directly connected, Ethernet0/2.300
CadizPlant-Rtr
CadizPlant-Rtr#sh ip route
      1.0.0.0/30 is subnetted, 1 subnets
D EX     1.1.1.0 [170/281856] via 192.168.203.1, 00:47:45, Ethernet0/0.300
C        10.168.192.0/24 is directly connected, Loopback2
L        10.168.192.254/32 is directly connected, Loopback2
D EX     10.168.236.0/24
D EX     10.168.250.192/26
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.192.0/24 is directly connected, Loopback200
L        172.16.192.254/32 is directly connected, Loopback200
C        192.168.203.0/30 is directly connected, Ethernet0/0.300
L        192.168.203.2/32 is directly connected, Ethernet0/0.300
DENTST-Rtr
DenverTest-Rtr#sh ip route
C        1.1.1.0/30 is directly connected, Serial2/0.100
L        1.1.1.1/32 is directly connected, Serial2/0.100
      10.0.0.0/8 is variably subnetted, 3 subnets, 3 masks
B        10.168.236.0/24 [200/0] via 1.1.1.2, 00:58:28
C        10.168.250.192/26 is directly connected, Ethernet0/0.2
L        10.168.250.254/32 is directly connected, Ethernet0/0.2
DenverTest-Rtr#sh ip bgp
BGP table version is 13, local router ID is 10.168.250.254
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
* i 1.1.1.0/30       1.1.1.2                  0    100      0 i
*>                   0.0.0.0                  0         32768 i
* i 10.168.192.0/24  192.168.203.2       409600    100      0 ?
*>i 10.168.236.0/24  1.1.1.2                  0    100      0 i
*>  10.168.250.192/26
                       0.0.0.0                  0         32768 i
* i 172.16.192.0/24  192.168.203.2       409600    100      0 ?
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hello Quoc Le,
Here is the thing:
The problem is that Denver router does not know how to get to  192.168.203.2  so it will not install the routes on it's routing table (they are not valid... Missing the > on the BGP table)
How to fix it:
make sure you know how to get to 192.168.203.2 (Static route)
add the command bgp neig X.X.X.X next-hop-self on Router Cadiz-Rtr
Remember to rate all of the helpful posts.
For this community that's as important as a thanks.
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hello Quoc Le,
Here is the thing:
How to fix it:
Thanks! I was able to fix it, I was not advertising 192.168.203.2 network into BGP. Once I added that network, I was able to see 10.168.192.X network in the routing table. Thanks for the help.
Hello Quoc,
Exactly, that was the problem as I mentioned: We must have a route to the device that publishes the route
1308
