Community Member
EIGRP route influence broadcast
Is it possible to make route selection based on neighbors in eigrp on a broadcast network.
Detailed Question:
If i am learning same routes from different neighbours from same physical interface, Can in influence the route selection based on neighbors?
sample net work
  B--A--C  B and C are switches and A is a router bridging the interfaces. I ahve two neighbors on same BVI interface and receiving same subnets from both neighbors, need to influence one of them ( lets say i am using filterlist on other end, ie B and C)
But how do i influence routes going to one of them  from A , bcoz both neighbors are on same interface ...is it possible ?
if yes how ..
1 REPLY
Hall of Fame Super Blue
Re: EIGRP route influence broadcast
Detailed Question:
sample net work
if yes how ..
You could use an offset-list to change the metrics. You would still need to apply these on B and/or C though. It's not actually using A to influence the routes but it would have the same effect.
Jon
163
