EIGRP Routing Problem
Hi all,
I recently move sites to a VPLS provider.
I setup all routers to run EIGRP. This company have a particular setup between HQ and DR sites (Disaster & Recovery)
Please see attached.
The problem resides when I enable EIGRP in the inside interface in the DR router, all the other locations seems to start dropping connectivity.
I think this is because all remotes locations have two paths to the bridge network behind the HQ and DR routers, and causes a loop.
I would like to have HQ router as the primary router and DR router as my backup path to the bridge network.
Thanks in advance for your feedback.
  • WAN Routing and Switching
1 REPLY
Hall of Fame Super Silver
Re: EIGRP Routing Problem
Hello Aosondoval,
on DR router you should use the offset-list feature in order to make its routes with an higher metric
access-list 11 permit any
router eigrp XX
offset-list 11 out 100
the command will increase the delay component of EIGRP routes sent out the specified interface
see
http://www.cisco.com/en/US/docs/ios/iproute_eigrp/command/reference/ire_i1.html#wp1035554
Hope to help
Giuseppe
156
