EIGRP Stub receiving Default Route
I have a lab where my EIGRP Stub router is receiving all routes int the network and not just a default route. Any suggestions?
Re: EIGRP Stub receiving Default Route
The EIGRP stub feature is used to limit the scope of EIGRP query messages,
and to limit what routes a neighbor advertises.
Hitesh Vinzoda
Any other suggestions? Can this be done? In the BSCI book it clearly states a default route can be substituted for the rest of the routes, but I understand what you have said.
Hall of Fame Super Silver
Ryan
Configuring a router as EIGRP stub affects how the router reacts when it receives an EIGRP query and what the router will advertise. But configuring the router as EIGRP stub does not affect whether the router learns the full route table or only a default route. To accomplish what you want (the stub router learns only a default route from upstream) you must configure the upstream router to send only a default route. You can configure the upstream router with a distribute-list or with summary-address to achieve that the upstream router will only advertise a default route to the downstream stub router.
Rick
Thank you Rick and Hitesh for helping me undterstand EIGRP Stub routing. I was able to get the default route in the Stub routing table using the summary address command. I am able to ping to the connected interface but not any interfaces or networks past that. Am I missing something about default routing?
R2#sh ip route
Gateway of last resort is 172.16.12.1 to network 0.0.0.0
172.16.0.0/24 is subnetted, 2 subnets
C 172.16.12.0 is directly connected, Serial1
C 172.16.7.0 is directly connected, Loopback0
D* 0.0.0.0/0 [90/2681856] via 172.16.12.1, 00:05:25, Serial1
R2#
R2#
R2#
R2#ping 172.16.9.1 source s1
Sending 5, 100-byte ICMP Echos to 172.16.9.1, timeout is 2 seconds:
Packet sent with a source address of 172.16.12.2
Success rate is 0 percent (0/5)
R8#sh ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
172.16.0.0/24 is subnetted, 5 subnets
C 172.16.12.0 is directly connected, Serial1/0
D 172.16.15.0 [90/642560] via 172.16.9.2, 00:46:52, Serial1/2
C 172.16.9.0 is directly connected, Serial1/2
D 172.16.10.0 [90/1026560] via 172.16.9.2, 00:46:31, Serial1/2
D 172.16.7.0 [90/20640000] via 172.16.12.2, 00:06:09, Serial1/0
D* 0.0.0.0/0 is a summary, 00:41:46, Null0
R2 is the Stub and R8 the Distributiob Router
Ryan
The routing table in R2 seems to have a valid default route pointing to R8. R8 sees the ping destination of 172.16.9.0 as a connected subnet and sees the connected serial subnet to R2 and the route to R2's loopback interface. So it looks to me like that part of the routing for the ping from R2 should work. I wonder if there is some other issue in the config (perhaps an access list) or perhaps the ping destination address is not the address of the interface on R8 (in which case we would need to see the routing table of the router where the address is).
I do note that on the routing table of R8 the default route is a route to null0, which is a result of the summary address that you configured. Is R8 supposed to have a valid default route?
Perhaps if you provide some additional details (like router configs) we might better understand what the problem is.
Rick
There are no access lists or any other configs besides routing and interface commands.
Here is the router config for R2:
hostname R2
interface Loopback0
ip address 172.16.7.1 255.255.255.0
interface Serial0
no ip address
shutdown
interface Serial1
ip address 172.16.12.2 255.255.255.0
interface TokenRing0
no ip address
shutdown
router eigrp 1
network 172.16.7.0 0.0.0.255
network 172.16.12.0 0.0.0.255
no auto-summary
eigrp stub connected summary
And R8:
hostname R8
interface Ethernet0/0
no ip address
shutdown
half-duplex
interface Serial1/0
ip address 172.16.12.1 255.255.255.0
ip summary-address eigrp 1 0.0.0.0 0.0.0.0 5
clock rate 64000
interface Serial1/1
bandwidth 3000000
ip address 172.16.8.1 255.255.255.0
interface Serial1/2
bandwidth 1000000
ip address 172.16.9.1 255.255.255.0
clock rate 64000
interface Serial1/3
no ip address
shutdown
router eigrp 1
network 172.16.8.0 0.0.0.255
network 172.16.9.0 0.0.0.255
no auto-summary
R8#sh ip int b
Ethernet0/0 unassigned YES NVRAM administratively down down
Serial1/0 172.16.12.1 YES NVRAM up up
Serial1/1 172.16.8.1 YES NVRAM down down
Serial1/2 172.16.9.1 YES NVRAM up up
When I replace the sum address command with 172.16.0.0 255.255.0.0 I am able to ping out to remote network listed in R8s routing table. I have also tried using network 0.0.0.0 on both routers but it did not work. What do you think? Thanks in advance
Any other possible suggestions?
Hello Ryan,
try to use
ip summary address eigrp 100 0.0.0.0 0.0.0.0 201
the way you are generating the default summary route on R8 may be overriding a legitimate default-route.
a default-route to null0 is a silent discarder of packets (waste bin)
Note:
Rick had noted this in his post I had just developed the argument.
Hope to help
Giuseppe
2010
