EIGRP through ISP links.
Dosorio31
Hello all,
How can I work with EIGRP in the company routers, if in the middle of the links I have the ISP routers and I don't want them to participate in the EIGRP process?
7 Replies 7
Then a logical interface ( tunnel ) between your routes will do it, eigrp only on the tunnel.
Dan
yes you can make that interface passive interface
Parves Ataev
You can do it with GRE tunnel, also you can secure the tunnel with Ipsec. You may find the following link useful
http://www.cisco.com/en/US/tech/tk827/tk369/tech_configuration_examples_list.html
fb_webuser
Level 6
Level 6
Let's say you have interface Fa0/0 connected to ISP router, then configure Fa0/0 as passive-inetface under EIGRP like this: NJ-R1#config t
Enter configuration commands, one per line. End with CNTL/Z.
NJ-R1(config)#router eigrp 20
NJ-R1(config-router)#passi?ve-interface fa0/0
Posted by WebUser Neeraj Jagga from Cisco Support Community App
fb_webuser
Level 6
Level 6
We featured your question on our pages. Check out the responses here http://www.facebook.com/CiscoSupportCommunity/posts/394754587225752
Posted by WebUser Cisco NetPro from Cisco Support Community App
fb_webuser
Level 6
Level 6
Use GRE tunnel between your own routers, passing through ISP router. And under eigrp network command use, GRE interface IP for neighboring purpose.
Posted by WebUser Nagiswaren Utheyakumar from Cisco Support Community App
Ivan Krimmel
Level 7
Level 7
MPLS VPN woould be an option here ;)
