06-08-2012 08:54 AM - edited 03-04-2019 04:37 PM
Hi everyone, here is an output from my router which has 2 vpn tunnels going to separate routers. Why does it say 1 Successor? Shouldn't it be 2 Sucessors?
#sh ip eigrp top 172.18.24.0/24
EIGRP-IPv4 Topology Entry for AS(1)/ID(1.1.1.203) for 172.18.24.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 1331456
Descriptor Blocks:
10.10.200.24 (Tunnel0), from 10.10.200.1, Send flag is 0x0
Composite metric is (1331456/1305088), route is Internal
Vector metric:
Minimum bandwidth is 100000 Kbit
Total delay is 51010 microseconds
Reliability is 255/255
Load is 12/255
Minimum MTU is 1400
Hop count is 2
10.10.201.24 (Tunnel1), from 10.10.201.1, Send flag is 0x0
Composite metric is (1561856/1305088), route is Internal
Vector metric:
Total delay is 60010 microseconds
Load is 1/255
Minimum MTU is 1400
Hop count is 2
Solved! Go to Solution.
06-08-2012 08:59 AM
Ricky,
You'll only have 1 successor which will be in the routing table (unless metrics match exactly, in which case you can have multiple routes in the routing table). The other route is a feasible successor. If you lose the connection that leads to this route, EIGRP can fail over to the feasible successor without having to query neighbors.
HTH,
John
06-08-2012 08:59 AM
Ricky,
HTH,
John
06-08-2012 09:06 AM
06-08-2012 10:38 AM
Hi John, I have another question that is related. If you see the output below, Descriptor Block for 10.10.200.155 has ECMP mode set to Advertise by default. Whereas for 10.10.201.155, it's set differently. What is ECMP mode? I am having a weird random and sporadic issue on my network which I am trying to zero in on where 2 routers know routes to one another but can't ping each other. Whereas I can ping both of them from everywhere else in the network and vice versa. There are no ACLs involved in my internal network.
EIGRP-IPv4 Topology Entry for AS(1)/ID(192.168.155.150) for 172.18.155.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 1620480
Descriptor Blocks:
10.10.200.155 (Tunnel0), from 10.10.200.1, Send flag is 0x0
Composite metric is (1620480/1308160), route is Internal
Vector metric:
Minimum bandwidth is 8192 Kbit
Total delay is 51100 microseconds
Load is 67/255
Minimum MTU is 1400
Hop count is 2
ECMP Mode: Advertise by default
10.10.201.155 (Tunnel1), from 10.10.201.1, Send flag is 0x0
Composite metric is (1850880/1308160), route is Internal
Vector metric:
Total delay is 60100 microseconds
Load is 1/255
Minimum MTU is 1400
Hop count is 2
ECMP Mode: Advertise out Tunnel1
06-08-2012 10:50 AM
Ricky,
ECMP is equal cost multipath routing and basically means that it will support multiple paths in the routing table. If I remember right in a previous post, didn't you want to support only 1 route in the routing table? I think the fix was to set "maximum-paths" to 1. I assume that ECMP is "advertise by default" because it's the only route in the routing table. If you had both routes, it may say advertise by default for both. I have to lab this one up and get back to you....
HTH,
John
06-08-2012 11:11 AM
Ricky,
Unfortunately, I can't verify this. The version of IOS that I run doesn't have ECMP supported in the topology listing, so I can't tell you for sure what manipulates it. Maybe someone else would be able to help.
John
06-08-2012 11:12 AM
Hi John,
Yes you are correct. I am using maximum-path 1 for all my EIGRP instances. I decreased the delay on Tunnel0 to make it the preffered route for all my traffic. Tunnel 1 is used for backup. I am not sure why ECMP mode for Tunnel1 is saying Advertise out Tunnel1.
No problem Thanks for trying anyways
06-08-2012 11:19 AM
Ricky,
I found this, and surprisingly enough I was very close
From this link:
The following sample output from the show ip eigrp topology prefix command displays ECMP mode information when the no ip next-hop-self command is configured without the no-ecmp-mode option in an EIGRP topology. ECMP mode provides information about the path that is being advertised. If there is more than one successor, the top most path will be advertised as the default path over all interfaces, and "ECMP Mode: Advertise by default" will be displayed in the output. If any path other than the default path is advertised, "ECMP Mode: Advertise out
Device# show ip eigrp topology 192.168.10.0/24 EIGRP-IPv4 Topology Entry for AS(1)/ID(20.20.100.100) for 192.168.10.0/24 State is Passive, Query origin flag is 1, 2 Successor(s), FD is 284160 Descriptor Blocks: 10.100.1.0 (Tunnel0), from 10.100.0.1, Send flag is 0x0 Composite metric is (284160/281600), route is Internal Vector metric: Minimum bandwidth is 10000 Kbit Total delay is 1100 microseconds Reliability is 255/255 Load is ½55 Minimum MTU is 1400 Hop count is 1 Originating router is 10.10.1.1 ECMP Mode: Advertise by default 10.100.0.2 (Tunnel1), from 10.100.0.2, Send flag is 0X0 Composite metric is (284160/281600), route is Internal Vector metric: Minimum bandwidth is 10000 Kbit Total delay is 1100 microseconds Reliability is 255/255 Load is ½55 Minimum MTU is 1400 Hop count is 1 Originating router is 10.10.2.2 ECMP Mode: Advertise out Tunnel1
06-10-2012 02:26 PM
Thanks John for the explaination. I am still wondering whether using maximum-paths 1 command in EIGRP in a dual hub dual-dmvpn cloud scenario is beneficial. I am using Tunnel0 to Hub1 as the primary link for all sites and Tunnel1 to Hub2 aS backup for all sites. Both tunnels are on separate subnets. Way I am accomplishing this is by adjusting the delay on both interfaces. Since delay on Tunnel0 is always less than tunnel1, sites will always pick tunnel0 as the main link. Having maximum-paths 1 may not serve any purpose at this point unless I had 2 headend-hubs on the same inner DMVPN network.
