EIGRP Using SLOW connection vice fast connection
cybrsage
I am perplexed. My router is choosing the slow conneciton over the fast connection for EIGRP routes.
This is a dual hub and spoke design, with all the sites having a full T1 to the main (all via S0/0/0.1) and only 256k to the backup (all via the S0/0/0.2). For spoke site A to talk to spoke site B, it would either use two T1 links through the main hub or two 256k links through the backup hub.
Here is my setup (IPs have been changed):
interface Serial0/0/0.1 point-to-point
bandwidth 1544
ip address 1.1.1.1 255.255.255.252
ip nbar protocol-discovery
ip policy route-map nachi
frame-relay interface-dlci 16
interface Serial0/0/0.2 point-to-point
bandwidth 256
ip address 2.2.2.2 255.255.255.252
ip bandwidth-percent eigrp 1 10
no cdp enable
frame-relay interface-dlci 20
router eigrp 1
redistribute connected
redistribute static
passive-interface GigabitEthernet0/0
passive-interface GigabitEthernet0/1
network 1.1.1.0 0.0.0.255
network 2.2.2.0 0.0.0.255
no auto-summary
no eigrp log-neighbor-changes
neighbor 1.1.1.2 Serial0/0/0.1
neighbor 2.2.2.2 Serial0/0/0.2
route-map nachi permit 10
match ip address 2003
match length 92 92
set interface Null0
#show ip eigrp nei
IP-EIGRP neighbors for process 1
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
1 1.1.1.2 Se0/0/0.1 14 00:00:22 1244 5000 3 547766
0 2.2.2.2 Se0/0/0.2 10 00:04:51 32 2850 0 408246
#show ip eigrp top
IP-EIGRP Topology Table for AS(1)/ID(1.1.1.1)
P 0.0.0.0/0, 1 successors, FD is 10516992
via 2.2.2.2 (10516992/61952), Serial0/0/0.2
P 3.3.3.0/30, 1 successors, FD is 11023872
via 2.2.2.2 (11023872/10511872), Serial0/0/0.2
HELP!
19 Replies 19
194 input errors in 20 minutes, no other errors. Uses an external CSU/DSU so I cannot check a cisco WIC. I cleared the counters after you mentioned possible line errors, since I have been messing with the router for a bit.
I would look on the other end to see if you're getting errors there too. Then I would have the provider look at the line.
HTH, John *** Please rate all useful posts ***
No errors on that side, but I will have the provider fix the slowly incrimenting incoming errors at the spoke site.
I will put the result in this thread and close out with the problem solved and such after they are done testing.
Thanks for all your help so far!
mlund
Level 7
Level 7
I suspect this can be a mtu issue.
I would recomend you to set the mtu size to 1500 on the atm side.
/Mikael
I changed the MTU to 1500 on the ATM subinterface and that fixed the problem!
