EIGRP Using SLOW connection vice fast connection
I am perplexed. My router is choosing the slow conneciton over the fast connection for EIGRP routes.
This is a dual hub and spoke design, with all the sites having a full T1 to the main (all via S0/0/0.1) and only 256k to the backup (all via the S0/0/0.2). For spoke site A to talk to spoke site B, it would either use two T1 links through the main hub or two 256k links through the backup hub.
Here is my setup (IPs have been changed):
interface Serial0/0/0.1 point-to-point
bandwidth 1544
ip address 1.1.1.1 255.255.255.252
ip nbar protocol-discovery
ip policy route-map nachi
frame-relay interface-dlci 16
interface Serial0/0/0.2 point-to-point
bandwidth 256
ip address 2.2.2.2 255.255.255.252
ip bandwidth-percent eigrp 1 10
no cdp enable
frame-relay interface-dlci 20
router eigrp 1
redistribute connected
redistribute static
passive-interface GigabitEthernet0/0
passive-interface GigabitEthernet0/1
network 1.1.1.0 0.0.0.255
network 2.2.2.0 0.0.0.255
no auto-summary
no eigrp log-neighbor-changes
neighbor 1.1.1.2 Serial0/0/0.1
neighbor 2.2.2.2 Serial0/0/0.2
route-map nachi permit 10
match ip address 2003
match length 92 92
set interface Null0
#show ip eigrp nei
IP-EIGRP neighbors for process 1
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
1 1.1.1.2 Se0/0/0.1 14 00:00:22 1244 5000 3 547766
0 2.2.2.2 Se0/0/0.2 10 00:04:51 32 2850 0 408246
#show ip eigrp top
IP-EIGRP Topology Table for AS(1)/ID(1.1.1.1)
P 0.0.0.0/0, 1 successors, FD is 10516992
via 2.2.2.2 (10516992/61952), Serial0/0/0.2
P 3.3.3.0/30, 1 successors, FD is 11023872
via 2.2.2.2 (11023872/10511872), Serial0/0/0.2
HELP!
1 ACCEPTED SOLUTION
Silver
Re: EIGRP Using SLOW connection vice fast connection
I suspect this can be a mtu issue.
I would recomend you to set the mtu size to 1500 on the atm side.
/Mikael
Try setting the delay on the 256k lines higher than that of the T1s. The bandwidth setting should be taken into consideration when eigrp does it's calculation, but Cisco recommends tuning the delay parameters first.
HTH,
John
HTH, John *** Please rate all useful posts ***
I kept the delay of the T1 at 20,000 (default) and increased the delay of the 256k connection to 100,000 and there was no change.
Hall of Fame Super Bronze
Based on the EIGRP Nei output the 'Q' count on neighbor 1.1.1.1 is 3 which means there are 3 pending updates on this link.
The 'Q' count should be '0' thus I suggest inspecting the link for errors and such.
HTH,
__
Edison.
Inspecting the link for errors, as in Layer 1 and 2 errors, or configuation errors?
Based on the config portion you've posted, I don't see a configuration issue. Can you post the remote site config?
Edison,
Just throwing this out there since I'm trying to learn from this problem as well. Would putting a delay statement under his 256k link higher than his T1 fix the problem if the other side doesn't have any errors in the config either? I had seen that you said there were pending updates that were in the queue, so if that wasn't the problem would delay fix it?
John
Delay as well as bandwidth are part of the EIGRP metric calculation but it will not help any L1 L2 issues that are currently present as packets aren't leaving the interface in the correct manner.
He already has the bandwidth information so EIGRP will choose the higher bandwidth interface. You can use delay if you didn't want to use the bandwidth as part of the metric, IOW if bandwidth were equal but that's not the case here.
__
Edison.
Hall of Fame Super Silver
What I notice is that the show ip eigrp topology only shows entries from one neighbor. I wonder what we would get if Michael would post the output of show ip eigrp topology all. Perhaps that will clarify what is going on. I wonder if advertisements from the T1 neighbor are getting through.
Rick
Main Hub Site:
vc-class atm atm
vbr-nrt 30000 15000 256
vc-class atm Remote-1708-1708
vbr-nrt 1708 1708 32
interface ATM1/0
no ip address
ip route-cache flow
ip ospf priority 0
class-int atm
atm scrambling cell-payload
atm framing cbitplcp
no atm auto-configuration
no atm ilmi-keepalive
interface ATM1/0.68 point-to-point
description Connection to messed up spoke site
bandwidth 1708
ip address 1.1.1.2 255.255.255.252
pvc 3/68
class-vc Remote-1708-1708
vc-hold-queue 300
oam-pvc 0
router eigrp 1
redistribute static
passive-interface FastEthernet0/0
passive-interface FastEthernet0/1
neighbor 1.1.1.1 ATM1/0.68
no auto-summary
ATM to Serial? ugh. I suspect L1 L2 problems. Contact the provider. You also listed some input errors on the remote serial so...
TY, I am opening up a case with them now and will post the results.
I did a clear ip eigrp nei and grabbed a debug of the output. Here is part of it:
IP-EIGRP Route Events debugging is on
NEVC_2821#terminal monitor
NEVC_2821#clear ip eigrp 1 neighbors
NEVC_2821#
Aug 7 12:18:03.926 EDT: IP-EIGRP(Default-IP-Routing-Table:1): Processing incoming UPDATE packet
Aug 7 12:18:03.978 EDT: IP-EIGRP(Default-IP-Routing-Table:1): A.A.A.0/25 - do advertise out Serial0/0/0.2
Aug 7 12:18:03.978 EDT: IP-EIGRP(Default-IP-Routing-Table:1): Ext A.A.A.0/25 metric 28160 - 25600 2560
Aug 7 12:18:04.018 EDT: IP-EIGRP(Default-IP-Routing-Table:1): Processing incoming UPDATE packet
Aug 7 12:18:04.018 EDT: IP-EIGRP(Default-IP-Routing-Table:1): Int F.F.F.F/30 M 40516864 - 40000000 516864 SM 6169
6 - 56832 4864
Aug 7 12:18:04.018 EDT: IP-EIGRP(Default-IP-Routing-Table:1): route installed for F.F.F.F ()
...truncated...
Aug 7 12:18:04.749 EDT: IP-EIGRP(Default-IP-Routing-Table:1): Processing incoming UPDATE packet
Aug 7 12:18:04.757 EDT: IP-EIGRP(Default-IP-Routing-Table:1): A.A.A.0/25 - do advertise out Serial0/0/0.1
Aug 7 12:18:04.757 EDT: IP-EIGRP(Default-IP-Routing-Table:1): Ext A.A.A.0/25 metric 28160 - 25600 2560
...truncated...
Aug 7 12:20:47.310 EDT: IP-EIGRP(Default-IP-Routing-Table:1): ExtS A.A.A.0/25 M 4294967295 - 9999872 4294967295 S
...truncated...
Additional background info:
First started looking because site complained of slowness. I am using a netflow collector and saw that the site's incoming traffic was from the Main Hub site as expected, but all outgoing traffic was to the Backup Hub site.
Well, do you see any crc errors or anything on the T1 link?
194 input errors in 20 minutes, no other errors. Uses an external CSU/DSU so I cannot check a cisco WIC. I cleared the counters after you mentioned possible line errors, since I have been messing with the router for a bit.
I would look on the other end to see if you're getting errors there too. Then I would have the provider look at the line.
No errors on that side, but I will have the provider fix the slowly incrimenting incoming errors at the spoke site.
I will put the result in this thread and close out with the problem solved and such after they are done testing.
Thanks for all your help so far!
Silver
/Mikael
I changed the MTU to 1500 on the ATM subinterface and that fixed the problem!
360
