04-29-2014 09:38 AM - edited 03-04-2019 10:52 PM
There is no flags in eigrp update messages to withdraw the routes.How the neighbors are communicated about invalid routes?
Solved! Go to Solution.
04-30-2014 08:51 AM
EIGRP will update the same prefix with infinity metric. Any router on receiving a prefix with infinity metric will consider it as withdraw and remove from local table.
-Nagendra
04-30-2014 08:51 AM
-Nagendra
05-01-2014 01:11 AM
Hi Nagendra,
Thanks for your reply..I seen this in my lab and wanted to confirm with the experts.. thanks again.. could you please check and answer the below query as well..
https://supportforums.cisco.co
05-01-2014 04:19 AM
Current eigrp version is 2.. is there any major difference between version 1 and 2.. Couldnt find the answer in the web..
