EIGRP
Hi!
i have a couple of questions!
1)if we have 4 link, the first 3 is gig and the 4 one running on the gig interface, but the actual speed is 300M?
2)can i run Multilink bundle on this 4 Links(1 of the 4 in different speed 300M But running on the gig interface)?
3)how can i do load balence & redundancy for this 4 link?
4)do i need to do l3 etherchannel(L3) for the first 3 link,and the 4 link(300M) for backup?
5)i want to use EIGRP AS ROUTING PROTOCOL,How EIGRP Will work for this situation?
plz waiting ur kind reply...
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: EIGRP
From Cisco doc:-
EIGRP puts up to four routes of equal cost in the routing table, which the router then load-balances. The type of load balancing (per packet or per destination) depends on the type of switching being done in the router. EIGRP, however, can also load-balance over unequal cost links.
Note: Using max-paths, you can configure EIGRP to use up to six routes of equal cost.
Let us say there are four paths to a given destination, and the metrics for these paths are:
path 1: 1100
path 2: 1100
path 3: 2000
path 4: 4000
The router, by default, places traffic on both path 1 and 2. Using EIGRP, you can use the variance command to instruct the router to also place traffic on paths 3 and 4. The variance is a multiplier: traffic will be placed on any link that has a metric less than the best path multiplied by the variance. To load balance over paths 1, 2, and 3, use variance 2, because 1100 x 2 = 2200, which is greater than the metric through path 3. Similarly, to also add path 4, issue variance 4 under the router eigrp command. Refer to How Does Unequal Cost Path Load Balancing (Variance) Work in IGRP and EIGRP? for more information.
So in your case you have to look at metric for the L3 etherchannel and the metric for the wireless link and then work out how many times you have multiply the metric for your L3 etherchannel to get to the metric for your wireless link.
Note that the wireless link must be a feasible successor to be used in unequal cost load-balancing so refer back to earlier posts for info on how to do this.
Jon
Re: EIGRP
Friend,
There are 2 ways to use EIGRP over different bandwidth links if you want to loadbalance.
1. use the variance parameter and load balance
2. configure multilink on the 3 links and run eigrp on the multilink interface.
Below excerpt from a TAC response for loadbalancing on different speed links in a multilink
Multilink gives data to the links on demand.
Several small frames may land on one link to balance a large frame on another link. A fast link draws more data than a slow link. Over time, the amount of data sent on each link is proportional to its bandwidth.
MLPPP do make a point of spreading frames across all links as much as possible, and keeping all the links equally utilized. Hence if each link takes about the same amount of time to transmit the frames given to it, the results will approximate round-robin distribution.
If you want to have redundancy, then just make sure you run eigrp on the interface.
The traffic will be diverted to this link if all other linsk fail
HTH, rate if it does
Narayan
Re: EIGRP
hi Narayan!
10xs for ur response;what about the L3 etherchannel for 3 Link(1 gig each);and the 4 one 300m as backup?
10xs
Re: EIGRP
HI Experts!
in my situation L3 Etherchannel work or Multilink?what is the difference between them
10xs
Re: EIGRP
Sorry friend,
I didn't realise that you are using ethernet interfaces.
In this case you need to go with etherchannel as multilink is not supported on ethernet interfaces.
For etherchannel to work though, the interfaces parameters should match and the same should be reflected in the configuration
Narayan
Re: EIGRP
HI Narayan!
So i need to configure L3 etherchannel on the 3 gig interface;than adverisING it thr EIGRP?But what about the 4 one(300M)i want to use it as a backup?
10xs for ur reply
Re: EIGRP
Configure a port channel (layer 3 etherchannel) for the 3 links and the configure 300 mbps gig interface as a routed port. Thus, you would have two layer 3 interfaces. Configure both interfaces to run EIGRP. EIGRP, by default, does equal cost load balancing on up to 4 paths. Configure the bandwidth and delay to be the same on the port channel interface and the 300 mbps gig interface because EIGRP uses this for metric calculation. As far as Etherchannel/portchannel configuration is concerned you need to configure them the same way on both ends of the link.
This would provide load balancing and redundancy in case of failure of one of the links. Instead, if you only configure all 4 links, 3 as etherchannel & gig as layer 2 int, as layer 2 connections then STP would block one of the links and the other one would forward and this would provide redundancy but wouldn't load balance the traffic.
Sundar
Re: EIGRP
In case you want the 4th link to be purely standby, then configure etherchannel between the 3 links and run EIGRP over them.
Configure another eigrp neighbor relationship between your devices over the 4th link(300M). Fine tune the bandwidth & delay parameters on both sides of this link till you see it as a feasible successor to the etherchannel link.
Narayan
Re: EIGRP
HI
DO I NEED TO CONFIGURE VARIANCE UNDER THE EIGRO PROCCESS?IF SO WHAT VARIANCE VALUE could be
10XS AGAIN
Re: EIGRP
Varaince command is needed only if the metric via the L3 links are unequal. Assuming you have configured the same bandwidth/delay on both l3 interfaces the EIGRP metric should be the same and there would be no need for 'variance' command. It depends on how you have it configured.
Sundar
Re: EIGRP
HI Sundar!
10XS FOR UR REPLY,the First 3 link (1 gig each 1)also act as l3 etherchannel.the other link(routed) is wirless 300M,this wirless link for Backup if the leaser link( 3 link (1 gig each 1)fail wirless 300M must take care for traffic.
10xs
Re: EIGRP
Post the output of 'show ip eigrp nei' and 'show ip eigrp top' and let us know which link is what.
Re: EIGRP
HI!
Kindly have a look to the attached file as well as examine my config!it is rigt , where i am mistake
10xs for ur help
Re: EIGRP
As i said earlier configure 2 neighbor relationhip between the devices, one along the etherchannel and one along the wireless link.
For faster convergence, fine tune the parameters on the wireless links so that it becomes a feasible successor to the etherchannel.
This will ensure the link always acts as standby and will pass traffic only when the entire etherchannel fails.
Narayan
Re: EIGRP
HI Narayan!
Simple config to acheive this:fine tune the parameters on the wireless links so that it becomes a feasible successor to the etherchannel"
10xs
Re: EIGRP
hi the config for my Setup is here:
SW1-SUP720
interface GigabitEthernet2/1
description "L3 Point-To-Point Leaser-link to SW2-SUP2""
no ip address
channel-group 14 mode on
interface GigabitEthernet2/2
no ip address
interface GigabitEthernet2/3
no ip address
interface Port-channel14
ip address 192.168.1.1 255.255.255.252
interface GigabitEthernet3/1
description "L3 wirless link to SW2-SUP2"
ip address 192.168.1.4 255.255.255.252
router eigrp 1
network 192.168.1.0 0.0.0.3
no auto-summary
SW2-SUP2
description "L3 Point-To-Point Leaser-link to SW1-SUP720""
no ip address
no ip address
no ip address
ip address 192.168.1.2 255.255.255.252
description "L3 wirless link to SW1-SUP720"
ip address 192.168.1.5 255.255.255.252
router eigrp 1
no auto-summary
10xs
Re: EIGRP
use the bandwidth & delay command under the interface conencting to the wireless link.
you can check the FD of the etherchannel route through sh ip eigrp topology
if you can post the output of the above command it would be easier to suggest
Narayan
Re: EIGRP
Narayan 10xs 10xs for ur reply!
1)if i add the Bandwidth 300000 & delay under the interface,my config its work?
2)how can i configure the Delay that met my situation?
10xs
Re: EIGRP
if it works as desired then you do not need to configure the delay. These are the 2 parameters generally used to influence EIGRP metric.
It is not mandatory to use both of them :-)
BTW it is configured under the interface
int g 3/1
delay 2000
note: - delay is measured in tens of microseconds
Narayan
Re: EIGRP
1)what did u calcule for to acheive this?"delay 2000"
2)what about my config!it works or not?
10xs for ur time to help me
Re: EIGRP
Ali,
2000 was used just as an example.
Please go through this link to understand EIGRP metric calculation
http://www.cisco.com/warp/public/103/eigrp-toc.html#eigrpmetrics
Narayan
Re: EIGRP
10xs for ur reply
but what about my config?it works?
Re: EIGRP
Post the output of show ip EIGRP topology
Re: EIGRP
IP addressing is incorrect on wireless link and you don't have EIGRP enabled on that interface. Configure the following;
router eigrp 1
network 192.168.1.5 0.0.0.0
SW2-SUP2:
ip address 192.168.1.6 255.255.255.252
router eigrp 1
network 192.168.1.6 0.0.0.0
Sundar
Re: EIGRP
hi royalblues!
10xs for ur reply!the setup still on the Peapar;i want to ghather all required info before the Tuning!but the Scenario & the prevuious diagrams & config shoud run on the 2 6509
10xs
Re: EIGRP
Ali,
Just mention the bandwidth under the wireless link as 300000. This will ensure that it does not become the successor.
Once this is done, do a sh ip eigrp topology and see whether the wireless route comes up as FS in the table. Then you can start tuning these values till it appears in the topology as a FS.
And as Sundar has posted please ensure EIGRP is running on this interface.
Note: - Even if the link is not a FS, eigrp will route the traffic over this link. It only does a local computation (by sending queries to the neighbor).
This process does not take place if the route is installed as a FS.
Another way is to add a floating static route with an AD greater than 90 using the wireless link. This route will be installed once the EIGRP route fails.
Narayan
Re: EIGRP
HI!
We dont need Static route;we only need EIGRP AS ROUTING PROTOCOLE.
ANY COMMENTS
10XS FOR UR TIME TO HELP ME!!
Re: EIGRP
does EIGRP Send traffic also over the wirless even if the entire channel still up and working?or the wirless comes up when the L3 ethechannel down?
10xs for ur help!!!
Re: EIGRP
Eigrp will not send traffic over the wireless link until the L3 etherchannel goes down. When the layer 3 etherchannel goes down the route will be removed from the routing table.
EIGRP will then use the wireless link as an alternative route.
If you wanted to send traffic over both links you would need to use the variance command.
Jon
Re: EIGRP
Hi Jon!
10xs for ur reply!so what the variance cpild be in my situation?
10xs
358
