Enable CEF on ISDN 802 Router
I'm trying to enable CEF on 802 ISDN router but cannot find the command?
1 ACCEPTED SOLUTION
Re: Enable CEF on ISDN 802 Router
hi,
Unfortunately, it seems that the 802 doesn't support CEF.
Always use "Cisco Feature Navigator":
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
use "ip cef" in the global configuration.
What is your IOS, please do "show ver" ?
Mohammed Mahmoud.
ip cef does not work
I'm running 12.1(3)XG5 and 12.2(37) on the routers.
I'm trying to add the command, "ip verify unicast reverse-path" and it tells me to enable CEF first, so it this IOS must support it
router(config-if)#ip veri u r
% CEF not enabled. Enable first
router(config)#ip cef
% Invalid input detected at '^' marker.
hi,
Mohammed Mahmoud.
105
