Encryption between Switch ports
Hi Guys,
I have requirement where in i need to set up encryption between two systems connected to a switch. Is there any possible way to achieve this in any cisco switch.
I would appreciate if some one could share some ideas or recomendations wrt my requirement.
S K
Hall of Fame Super Blue
Re: Encryption between Switch ports
jonnydeep08 wrote:
Hi Guys,
S K
SK
Not with switches. You should probably look at software that can be used on the machines themselves eg. could you ssh for example to tunnel everything ?
But switches don't do this sort of thing.
Jon
Jon, your reply is correct, but I just want to understand something from user's question:
"I have requirement where in i need to set up encryption between two
systems connected to a switch"
If you have 2 devices connected through a switch, but the devices that need encryption are those 2 end devices, then the switch doesn't need to have any ideea about encryption protocols, but only that 2 devices. Switch will be just a device in the middle forwarding traffic from and to your devices.
I hope you understand what point is not clear to me.
Regarding Cisco switch and encryption, see Jon's excellent reply!
Calin
thanks for replying Jon/Calin, my requirement is to have encryption between to 2 end systems connected to a switch and i was expecting some work around in similar lines to IPSEC VPN and was just wondering if there is any advance security  feature set avialable in cisco IOS which can be helpful to achieve this.
428
