Webcast-Catalyst9k
Ensuring Symmetrical Routing
How do we ensure symmetrical routing between a remote-site PC accessing non-critical traffic (email) over carrier 1 and critical traffic (ERP-Application) over carrier 2 to HQ?
We are migrating from a dual-carrier hub-n-spoke Frame network (OSPF-CEF destination based session) to a dual-carrier MPLS network (OSPF-BGP)where we want to influence critical traffic over carrier one and non-critical traffic over the other while maintaining symmetrical routing.
Re: Ensuring Symmetrical Routing
Are your servers in the same IP subnet? If they are, without NAT-ing, the only way I can think of is using policy-based routing.
If they are on different subnets, then another question I have is: what routing protocol do you run between your CPE (CE router) to your provider's MPLS edge (PE router)? If it's BGP, it's potentially quite straightforward: use AS_PATH prepending. Obviously you'd have to work with your MPLS providers to ensure your BGP metric will reflect on to the MPLS network as well.
HTH.
Unfortunately, we have servers inter-mixed within the same subnet (ERP & email). We concluded the same solution, PBR.
BTW, we are running BGP between CE-PE but at the remote end it would be the same device accessing the same subnet (ERP & email) at HQ.
Thank you for the input.
140
