Community Member
Error opening crashinfo - 7206 with NPE-300 doesn't write crash file
From SHOW TEC we get:
The last crashinfo failed to be written.
Please verify the exception crashinfo configuration
the filesytem devices, and the free space on the
filesystem devices.
Using crashinfo_FAILED.
%Error opening crashinfo_FAILED (File not found)
----------------- show bootflash: all ------------------
-#- ED ----type---- --crc--- -seek-- nlen -length- -----date/time------ name
1 .. image 08FBD400 350040 26 3211200 Dec 14 1916 13:47:24 c7200-boot-mz.120-5.T1.bin
2 .. crashinfo AFEACA14 37D36C 25 185003 Apr 29 2005 07:32:07 crashinfo_20050429-073207
11412 bytes available (3396460 bytes used)
Is this error due to lack of space on ths PCMCIA card?
Should a delete of the crashinfo file which is dated April (old) and a squeeze get rid of this problem?
1 REPLY
Silver
Re: Error opening crashinfo - 7206 with NPE-300 doesn't write cr
your MSFC2 crashes and you have a crashinfo file in your bootflash device, issue the more bootflash:crashinfo_filename command. The command displays the information from the crashinfo file. If you see the Mistral-3-Error message in the initial log section of the crashinfo log, determine if you have run into one of these common reasons
259
