Error while saving the configuration
raju
I'm trying to save the configuration in 1760 Router after adding so many static Routes and I'm getting the following error . Is there any way to compress without memory upgrade?
wr mem
Building configuration...
% Configuration buffer full, can't add command: 172.30.9.66 255.255.255.255
%Aborting Save. Compress the config.[OK]
attrgautam
Level 5
Level 5
Pls do a service compress-config. This will solve your issue
Thanx. Where should I issue this command ?. In Global mode or config mode.
It is global. the command is 'service compress-config'
It worked.
Thanx.
