Webcast-Catalyst9k
error while using compress config command
I'm getting the following error in 3550 Layer-3 Switch while trying to save the configuration.
ASP3550L3-1#wr
Building configuration...
% Warning: Saving this config to nvram may corrupt any network management or sec
urity files stored at the end of nvram.
Continue? [no]:
I tried to use the service compress-config and it gives the following error.
ASP3550L3-2(config)#service compress-config
Boot ROMs do not support NVRAM compression.
Disabling service compress-config.
Below is the ver and model of the 3550 Switch.
ASP3550L3-2#sh ver
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(19)EA1c, RELEASE SOFTWARE
(fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 03-Feb-04 05:31 by yenanh
Image text-base: 0x00003000, data-base: 0x0080DFF0
ROM: Bootstrap program is C3550 boot loader
ASP3550L3-2 uptime is 19 weeks, 1 hour, 24 minutes
System image file is "flash:c3550-i5q3l2-mz.121-19.EA1c/c3550-i5q3l2-mz.121-19.E
A1c.bin"
cisco WS-C3550-48 (PowerPC) processor (revision L0) with 65526K/8192K bytes of m
emory.
Processor board ID CAT0809R0TM
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 4 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0F:34:D0:E7:00
Motherboard assembly number: 73-5701-09
Power supply part number: 34-0967-02
Motherboard serial number: CAT08090SW5
Power supply serial number: LIT072700RZ
Model revision number: L0
Motherboard revision number: A0
Model number: WS-C3550-48-EMI
System serial number: CAT0809R0TM
Configuration register is 0x10F
Re: error while using compress config command
Cisco 3550 doesnt support config compression,do find the link and follow the workaround provided.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfab.shtml#cat3550
regds
Thanks ed.
301
