Community Member
Errormsg: %PQII_PRO_FE-4-QUEUE_FULL: Ethernet Switch Module transmit queue is full
Hello All,
i have some problems with an CISCO881-K9. We have two german telekom adsl connections with 16MB/1MB connected to the router. these two connection a load-balanced. Now after some time we are getting the errormsg: %PQII_PRO_FE-4-QUEUE_FULL: Ethernet Switch Module transmit queue is full.
After that message everything goes slow an connections are beeing dropped.
we already use the newes ios version
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.3(2)T, RELEASE SOFTWARE (fc3)
Here are the configuration:
! Last configuration change at 08:30:08 UTC Mon Jul 1 2013 by admin
version 15.3
no service pad
service password-encryption
hostname internet-gw
boot-start-marker
boot system flash c880data-universalk9-mz.153-2.T.bin
boot-end-marker
no aaa new-model
memory-size iomem 10
no ip domain lookup
ip cef
ip cef load-sharing algorithm include-ports destination
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ1645C0NK
track 1 interface Dialer1 ip routing
track 2 interface Dialer2 ip routing
interface FastEthernet0
description aDSL Telekom 1
switchport access vlan 2
no ip address
pppoe enable
pppoe-client dial-pool-number 1
interface FastEthernet1
description aDSL Telekom 2
switchport access vlan 4
no ip address
pppoe enable
pppoe-client dial-pool-number 2
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description Verbindung ins interne LAN
ip address 128.1.251.11 255.255.0.0
ip nat inside
ip nat enable
ip virtual-reassembly in
ip policy route-map HTTPS
interface Vlan1
no ip address
interface Vlan2
no ip address
pppoe enable
interface Vlan4
no ip address
pppoe enable
interface Dialer1
description aDSL Verbindung Telekom
mtu 1492
ip address negotiated
ip nat outside
ip nat enable
ip virtual-reassembly in max-reassemblies 128
encapsulation ppp
ip tcp adjust-mss 1416
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password
ppp pap sent-username
ppp ipcp dns request
no cdp enable
interface Dialer2
mtu 1492
ip nat outside
ip nat enable
encapsulation ppp
dialer pool 2
dialer-group 1
ppp chap hostname
ppp chap password
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map SDM_RMAP_1 interface Dialer1 overload
ip nat inside source route-map SDM_RMAP_2 interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 10 track 1
ip route 8.8.4.4 255.255.255.255 Dialer1 10 track 1
ip route 8.8.8.8 255.255.255.255 Dialer1 10 track 1
ip route 0.0.0.0 0.0.0.0 Dialer2 10 track 2
ip route 8.8.4.4 255.255.255.255 Dialer2 100 track 2
ip route 8.8.8.8 255.255.255.255 Dialer2 100 track 2
ip route 172.16.0.0 255.255.0.0 128.1.254.1
ip access-list extended HTTPS-LIST
permit tcp any any eq 443
ip access-list extended intern
permit ip 172.16.0.0 0.0.255.255 any
permit ip 128.1.0.0 0.0.255.255 any
ip access-list extended intern2
dialer-list 1 protocol ip permit
route-map HTTPS permit 1
match ip address HTTPS-LIST
set interface Dialer1
route-map SDM_RMAP_1 permit 1
match ip address intern
match interface Dialer1
route-map SDM_RMAP_2 permit 1
match interface Dialer2
access-list 1610 permit 172.16.0.0 0.0.255.255
access-list 1610 permit 128.1.0.0 0.0.255.255
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 1610 in
login local
transport input all
end
Community Member
I have the same problem. In my case I expect it is caused by LAN traffic (some strange packets). Last year I have opened TAC ticket, but after receiving test IOS I haven't seen it again. That problem has been reported since 2009 for Cisco1812 and latter 8xx, but I haven't seen the solution.
Kind regards
Jerzy
Community Member
I know this thread is very
I know this thread is very old, but I´m getting the same errors on a cisco 888. Casn you tell me what test IOS version did you received?
2111
