errors
Sir,
We are experiencing errors (CRC, frame, overrun , abort) on B1 & B2 channels of ISDN on Cisco 1841 router using WIC-1B-S/Tv3 card .
While the BRI interface is totally clean, no errors are being observed ..
can somebody help?
regds,
Aman
1 REPLY
Re: errors
You may want to check your IOS version against the bug toolkit. I have run across similar problems on MFT controllers using 12.4 code. If possible you may want to try to upgrade to the latest IOS first.
102
