Community Member
ES+ 40 card (7606)
1 port on the ES 40 card has both LED on.
documentation says:
Green and Amber On: Undefined condition.
what is that mean, good, bad ? don't use
thanks
1 ACCEPTED SOLUTION
Re: ES+ 40 card (7606)
Hi Atif,
Have you tried to swap SFP to 2/1? Change it and run the diag again. If problem presist, I think you might have an HW issue.
jerry
Hi Atif,
What is your version of IOS are you running? Can you post the output of show version and show module.
jerry
Community Member
only 1 port out of 40 is showing this message:
here it is.
PE4#sh ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICES-M), Version 12.2(33)SRD1, RELEASE SOFTWARE (fc4)
PE4#sh module
Mod Ports Card Type Model Serial No.
2 40 7600 ES+ 7600-ES+40G3CXL JAE1309493P
3 40 7600 ES+ 7600-ES+40G3CXL JAE1309493M
5 2 Route Switch Processor 720 (Active) RSP720-3C-GE JAE12024CGH
6 2 Route Switch Processor 720 (Hot) RSP720-3C-GE JAE1130RD6Z
Mod MAC addresses Hw Fw Sw Status
2 0024.f94c.0bc0 to 0024.f94c.0c1f 1.0 12.2(33r)SRD 12.2(33)SRD1 Ok
3 0024.f94c.0fd0 to 0024.f94c.102f 1.0 12.2(33r)SRD 12.2(33)SRD1 Ok
5 001b.d401.6e40 to 001b.d401.6e43 5.2 12.2(33r)SRB 12.2(33)SRD1 Ok
6 0007.0e61.d8c0 to 0007.0e61.d8c3 5.2 12.2(33r)SRB 12.2(33)SRD1 Ok
Mod Sub-Module Model Serial Hw Status
2 7600 ES+ DFC XL 7600-ES+3CXL JAE13094A08 1.0 Ok
2 7600 ES+ 40xGE SFP 7600-ES+40G JAE1309487B 1.0 Ok
3 7600 ES+ DFC XL 7600-ES+3CXL JAE13062AG2 1.0 Ok
3 7600 ES+ 40xGE SFP 7600-ES+40G JAE13094881 1.0 Ok
5 Policy Feature Card 3 7600-PFC3C JAE12035PJY 1.1 Ok
5 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE12035FCF 1.1 Ok
6 Policy Feature Card 3 7600-PFC3C JAE1130RWR3 1.1 Ok
6 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE1130RR38 1.1 Ok
Mod Online Diag Status
2 Pass
3 Pass
5 Pass
6 Pass
Hi Atif,
Have you tried the look at the Online Diagnostics result? Here is a link on how to run the diagnostic again and review the result
http://www.cisco.com/en/US/partner/docs/routers/7600/ios/12.2SR/configuration/guide/diags.html#wp1041583
HTH,
jerry
Community Member
I cannot access the ablve link.
I tried this, it gives error:
PE4#diagnostic mode enter module 2
Diagnostic mode is not supported in this image
Community Member
it gives me this message:
PE4#diagnostic start module 2 test 5 port 1
Diagnostic[Module 2]: Running test(s) 5 may disrupt normal system operation
Do you want to continue? [no]: yes
PE4#
*Jul 9 16:12:42.747: %DIAG-SP-6-TEST_RUNNING: Module 2: Running TestTransceiverIntegrity{ID=5} ...
PE4#
*Jul 9 16:12:42.747: %DIAG-SP-3-TEST_SKIPPED: Module 2: TestTransceiverIntegrity{ID=5} is skipped
on detail:
E4#show diagnostic result module 2 detail
Current bootup diagnostic level: minimal
Module 2: 7600 ES+ SerialNo : JAE1309493P
Overall Diagnostic Result for Module 2 : PASS
Diagnostic level at card bootup: minimal
Test results: (. = Pass, F = Fail, U = Untested)
5) TestTransceiverIntegrity:
Port 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
. U U U U U U U U U . U U U U U U U U . U U U U
Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
U U U U U U U U U U U U U U U U
Error code ------------------> 3 (DIAG_SKIPPED)
Total run count -------------> 0
Last test execution time ----> n/a
First test failure time -----> n/a
Last test failure time ------> n/a
Last test pass time ---------> n/a
Total failure count ---------> 0
Consecutive failure count ---> 0
Hi Atif,
Testid 5 is loopback only, I am interested with a full test (Testid 1-32).
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/diags.html#wp1041629
Also, do you have a SFP in the module? Or have you tried to remove and re-insert the line card?
jerry
Community Member
I have an SFP installed but for RJ45 type connector, using 2 ports 2/1 and 2/20(which has only green LED on).
please see attached.
Hi Atif,
jerry
376
