08-07-2012 01:08 PM - edited 03-04-2019 05:12 PM
I have a DS3 terminated on a 3825 with bridging configured with all interfaces in the same bridge group.The DS3 is frame-relay leading to my BGP neighbor.
I'm unable to get BGP established across the bridge. Frame is up and I can ping from BGP router 1 to the carrier neighbor.
The reason we want to do this is so we can have a failover router running BGP on this same single MPLS line.
I suspect it has to do with unicast forwarding but since BGP uses Unicast but I can't find where to enable this. I've tried ebgp-multihop but that gets no joy.
Ideas?
Carl King
08-07-2012 07:27 PM
Can you share your interfaces and BGP config? Hard to say without that.
08-08-2012 08:12 AM
The basics are in the drawing, but here you go.
## Router MPLS-DS3
int g0/0
no ip address
bridge-group 1
int g0/1
no ip address
bridge-group 1
interface Serial0.100 point-to-point
no ip address
frame-relay interface-dlci 100 ietf
bridge-group 1
bridge 1 protocol ieee
bridge irb
## Router BGP router 1
ip routing
int g0/0
ip address 2.2.2.1 255.255.255.252
router bgp 64600
neighbor 2.2.2.2 remote-as 65000
neighbor 2.2.2.2 default-originate
Again, 2.2.2.2 is pingable from 2.2.2.1, frame pvc is up.
Carl
08-08-2012 08:58 AM
Carl, my apologies the iPad app does not show images that's why I couldn't see you diagram.
I would check few things. See what IP address BGP is using to connect with the command "show tcp brief" and look for any port 179 source IP. Make sure these match on your bgp neighbors.
Because of the frame relay you might need eBGP multihop, might want to check that.
One other thing I would try is use this command on the FR " frame-relay map bridge 100".
If anything fails, "debug ip bgp events" or "debug ip packet (acl)" with the acl of tcp port 179.
Hope that helps.
Tom
