Webcast-Catalyst9k
Etherchannel on 7600 dropping packets - BUG ?
Hi All
I have an Etherchannel between 2 7600.
using a tester I can see that I am loosing packets, but looking at the usual stats I am unable to see where they are being dropped.
the total link is 2X10Gb and I am pumping 10Mb only. I also have WRED and broadcast storm control with 30% threshold.
-no drops registred at interface level.
-no drops at QOS level.
I removed Broadcast control, still dropping packets. the odd thing is that, when generating traffic from 1Mb-5Mb all is fine, after that I start dropping.
Any pointers or suggestions will be great help.
TIA
Sam
Re: Etherchannel on 7600 dropping packets - BUG ?
Adding configs.
please note, config for TE interfaces is obviously the same.
TIA
Sam
interface Port-channel1
switchport
switchport trunk allowed vlan 100
switchport mode trunk
no ip address
mls qos vlan-based
mls qos trust dscp
flowcontrol send off
storm-control broadcast level 30.00
storm-control multicast level 30.00
end
interface TenGigabitEthernet2/4 & TE1/4
switchport
no ip address
udld port aggressive
wrr-queue threshold 2 100 100 100 100 100 100 100 100
wrr-queue random-detect min-threshold 1 40 70 100 100 100 100 100 100
wrr-queue random-detect min-threshold 2 70 100 100 100 100 100 100 100
wrr-queue random-detect min-threshold 3 70 100 70 100 100 100 100 100
wrr-queue random-detect max-threshold 2 100 100 100 100 100 100 100 100
wrr-queue cos-map 3 1 3
wrr-queue cos-map 3 2 4
wrr-queue cos-map 3 3 6 7
mls qos vlan-based
mls qos trust dscp
channel-group 1 mode desirable
So show interfaces error counters look ok? Is your tester able to read jumbo frames as valid?
no errors on interfaces
no drops on polic? maps
no drops on WRED
no drops on MLS
tester shows frame loss
I am suspecting CSCee10005, but need to take down DEC and see what happens.
The only thing that is bugging me, is why are the packets dropping when I go over 5Mb.
There is absolutely no rate limiting anywhere else than those interfaces I am looking at.
TIA
Sam
283
