12-10-2007 08:32 AM - edited 03-03-2019 07:52 PM
Hi can anyone explain what is ethernet handoff?
12-10-2007 08:34 AM
Is the feed provided to you by the carrier (ISP). If they mentioned ethernet handoff, they imply a RJ45 connection to your equipment.
12-10-2007 08:37 AM
I have a router which has inbuilt 16 port switch module and so how to check if it has a port that supports this ethernet handoff?
12-10-2007 08:39 AM
You have 16 ports with RJ45, it does support ethernet handoff.
12-10-2007 08:46 AM
How to configure a port on the switch for making it to route the traffic using ethernet interface rather than the serial link?
12-10-2007 08:50 AM
karthik,
Your question is too vague.
We need more specifics. Network Diagram, current configuration, network requirements, hardware involved, etc.
The more information the better, a one liner won't cut it.
12-10-2007 08:53 AM
currently there is a serial link between two routers but because we are doing ethernet handoff on one router, i want to know how to make routing possible?
12-10-2007 08:57 AM
Just move the IP address under the serial interface over to the ethernet interface, if you are planning to keep the same P2P WAN subnet.
If you are planning to create a new P2P WAN subnet, then you need to include it in your current static/dynamic routing configuration.
12-13-2007 03:12 PM
Just to add on this: if my ISP delivers it as Fast-E handoff, is it still better to terminate it on a router or just directly on a switch?
What's the advantage of ordering an FE hand-off instead of the old-school serial interface?
12-13-2007 03:15 PM
I hate to answer with a question but,
how much bandwidth can you fit via that serial interface ?
12-13-2007 03:23 PM
It fits upto 1.5Mbps on that serial interface..
12-13-2007 03:23 PM
That's a point. But a DS3 card can give me a full 45 Mbps which is more than adequate for my application :-)
By the way on the other question what's the better wait to terminate it? On the router FE port or switch?
12-13-2007 03:30 PM
45Mbps at what cost ? :)
You can get a 100Mbps hand-off much cheaper nowadays ...
________
To answer your other question, it can terminate on either device. Choosing one over the other doesn't make better but it needs to meet your network design requirement.
If you have an office with a 10Mb hand-off, it's easier to drop a 3560 or 3750 switch and have the WAN and office connecting on the same device instead of having a router connecting to a switch.
12-13-2007 03:31 PM
the switch module that i have doesn't support layer 3 routing .... so i got struck to as how to terminate it... probably i need to buy a new 1800 router to get an ethernet interface or buy a HWIC card...
12-13-2007 03:32 PM
Yes it does, you need to configure SVIs (Switch Virtual Interfaces) to route between those ports, just like a typical Catalyst Switch.
interface fx/x
switchport access vlan 2
interface vlan 2
ip address x.x.x.x y.y.y.y
