Ethernet over GRE tunnel doesn't recognize messages
tehemulele
Helllo,
I'm configuring my ASR 1000 router with an Ethernet over GRE tunnel. Anytime I sent the Ethernet over GRE messages to the tunnel, the ASR router didn't recognize the messages were sent over the GRE tunnel. The ASR said that the messages were received on the LAN management interface, which was not what I intended. I'm wondering if the messages were not encapsulated correctly or I need to configure more on the ASR. I attached an ARP over GRE message capture.
Here is the router's log
*Jun  4 13:48:00.371: IP ARP: rcvd req src 10.14.18.1 0025.642c.4441, dst 10.14.18.152 GigabitEthernet0
*Jun  4 13:48:01.404: IP ARP: rcvd req src 10.14.18.1 0025.642c.4441, dst 10.14.18.152 GigabitEthernet0
*Jun  4 13:48:02.503: IP ARP: rcvd req src 10.14.18.1 0025.642c.4441, dst 10.14.18.152 GigabitEthernet0
Here is my ASR configuration
version 15.3
no platform punt-keepalive disable-kernel-core
hostname moonstone
boot-start-marker
boot system flash bootflash:asr1000rp2-adventerprise.03.09.01.S.153-2.S1.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
ip dhcp pool dhcp_over_gre_1
 network 172.16.0.0 255.255.0.0
ip dhcp pool dhcp_over_gre_2
 network 212.1.0.0 255.255.0.0
ip dhcp pool dhcp_over_gre_3
 network 200.1.0.0 255.255.0.0
redundancy
 mode sso
ip ftp source-interface GigabitEthernet0
ip tftp source-interface GigabitEthernet0
interface Loopback0
 ip address 130.130.130.130 255.255.255.255
interface Tunnel0
 mac-address 0000.5e00.0001
 ip address 172.16.1.1 255.255.255.0
 no ip redirects
 tunnel source TenGigabitEthernet1/0/0
 tunnel mode ethernet gre ipv4
interface GigabitEthernet0/0/0
 no ip address
 ip broadcast-address 0.0.0.0
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 negotiation auto
interface GigabitEthernet0/0/3
 no ip address
 negotiation auto
interface GigabitEthernet0/0/4
 no ip address
 negotiation auto
interface GigabitEthernet0/0/5
 ip address 70.0.1.2 255.255.255.0
 negotiation auto
interface GigabitEthernet0/0/6
 no ip address
 negotiation auto
interface GigabitEthernet0/0/7
 no ip address
 negotiation auto
interface GigabitEthernet0/0/8
 no ip address
 negotiation auto
interface GigabitEthernet0/0/9
 no ip address
 negotiation auto
interface TenGigabitEthernet1/0/0
 ip address 200.1.1.1 255.255.255.0
interface TenGigabitEthernet1/0/0.2
 encapsulation dot1Q 2
interface TenGigabitEthernet2/0/0
 ip address 212.1.1.1 255.255.255.0
 vrf forwarding Mgmt-intf
 ip address 10.14.18.130 255.255.255.0
 negotiation auto
 no mop enabled
router ospf 9
 network 70.0.1.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
ip route vrf Mgmt-intf 10.14.0.0 255.255.0.0 10.14.18.1
ip route vrf Mgmt-intf 10.15.0.0 255.255.0.0 10.14.18.1
control-plane
line con 0
 stopbits 1
line vty 0 4
 exec-timeout 0 0
 password spirent
 login
end
5 Replies 5
Hello
You could try using the gre ip mode instead and allow for the fragmentation regards the gre overhead.
Also i dont see the tunnel ip subnet or the physical interface being advertised for readability either by static or dynamic addressing..
int interface Tunnel0
ip mtu 1400
ip tcp adjust-mss 1360
tunnel mode gre ip
res
Paul
Kind Regards
Paul
Hi Paul,
My test needs the tunnel mode to be Ethernet over GRE. How do I set up so the tunnel ip subnet and the physical interface are reachable?
Don
Not sure about your diagram, please send your full topology diagram , moreover, see this link , how to configure ethernet over gre. i think you are missing something.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/interface/configuration/xe-3s/ir-xe-3s-book/ir-eogre.html#task_82FE2071B9804F118B0BF4AA3D6A8500
kazim
"please rate me if post helpful"
I was following the same link but didn't get far. I'm wondering what kind of encapsulation the ARP packet should have when it arrives at the ASR physical interface. As you can see in the attachment, the ARP message has this format: (GRE) Ethernet header -> (GRE) IP header -> GRE -> (ARP) Ethernet header -> ARP. Can I use this encapsulation (Physical) Ethernet header -> (Physical) IP header -> (GRE) Ethernet header -> (GRE) IP header -> GRE -> (ARP) Ethernet header -> ARP?
tehemulele
I figured out what the problem is. I sent the GRE encapsulated messages to the wrong address. It’s not the address on the GRE tunnel. It has to be the address of the tunnel source. Thanks for you guys time!
