Webcast-Catalyst9k
Ethernet to T1
I have a 1601R router with a serial connection to a Audit 600 which is connected to Westell T1 Factory Loopback unit A90-310027 (Audit and Westell owned and maintained by Phone Company). If I upgrade to a 1841 router do I need to purchase the WIC 1DSU card? Can I go straight into the Westell with an Ethernet cable?
1 REPLY
Purple
Re: Ethernet to T1
You will have to get the WIC-1DSU in order to connect to your T1. You cannot, unfortunately, use any of the built-in ethernet ports for this purpose.
Hope that helps - pls rate the post if it does.
Paresh
99
