EVN design - route replication
I am working the EVN design  but i am facing problem in the route replication (router leaking in VRF). I also read some cisco docs but did not get the
result.
Kindly look at below config and correct if there is any improper config
any example for EVN is helpful
sh run
Router#sh running-config
Building configuration...
Current configuration : 15692 bytes
! Last configuration change at 15:42:16 UTC Sat Jul 7 2012
! NVRAM config last updated at 15:08:38 UTC Sat Jul 7 2012
version 15.0
service counters max age 5
hostname Router
boot-start-marker
boot system flash bootdisk:s2t54-advipservicesk9_npe-mz.SPA.150-1.SY1.bin
boot-end-marker
vrf definition green
vnet tag 20
rd 2:2
address-family ipv4
  route-replicate from vrf red unicast ospf 10
exit-address-family
vrf definition red
vnet tag 10
rd 1:1
address-family ipv4
  route-replicate from vrf green unicast ospf 20
exit-address-family
vrf list abc
member red
enable password cisco
no aaa new-model
platform ip cef load-sharing ip-only
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 192.168.20.1 192.168.20.10
ip dhcp pool vlan10
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
ip dhcp pool vlan20
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
no ip domain-lookup
ip domain-name tera.com
spanning-tree mode rapid-pvst
redundancy
main-cpu
  auto-sync running-config
mode sso
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface GigabitEthernet7/1
no ip address
shutdown
interface GigabitEthernet7/2
no ip address
shutdown
interface GigabitEthernet7/3
no ip address
shutdown
interface TenGigabitEthernet7/4
no ip address
shutdown
interface TenGigabitEthernet7/5
no ip address
shutdown
interface GigabitEthernet10/1
switchport
switchport access vlan 100
switchport mode access
interface GigabitEthernet10/2
switchport
interface GigabitEthernet10/3
switchport
interface GigabitEthernet10/4
switchport
interface GigabitEthernet10/5
switchport
interface GigabitEthernet10/6
switchport
interface GigabitEthernet10/7
switchport
interface GigabitEthernet10/8
switchport
interface GigabitEthernet10/9
switchport
interface GigabitEthernet10/10
switchport
interface GigabitEthernet10/11
no ip address
shutdown
interface GigabitEthernet10/12
no ip address
shutdown
interface GigabitEthernet10/13
switchport
interface GigabitEthernet10/14
switchport
switchport access vlan 20
interface GigabitEthernet10/15
no ip address
shutdown
interface Vlan1
ip address 192.168.100.15 255.255.255.0
interface Vlan10
vrf forwarding red
ip address 192.168.10.1 255.255.255.0
interface Vlan20
vrf forwarding green
ip address 192.168.20.1 255.255.255.0
interface Vlan100
ip address 192.168.1.254 255.255.255.0
router ospf 10 vrf red
redistribute connected subnets
redistribute vrf green ospf 20 subnets
network 192.168.10.0 0.0.0.255 area 0
router ospf 20 vrf green
redistribute vrf red ospf 10 subnets
network 192.168.20.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
service-policy input policy-default-autocopp
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password cisco
login
transport input all
ntp source Vlan100
ntp master 1
no event manager policy Mandatory.go_switchbus.tcl type system
end
Router#
175
