08-26-2008 03:04 PM - edited 03-03-2019 11:17 PM
Hello, I am trying to set up charter cable on a 1811 router. I am using SDM to set it up, and the FE1 interface is set as DHCP. When testing the interface, I'm getting an error message <exit interface failed> and the recommended action <Select 'User-specified' option or add a 'host specific/network specific/default' route through this interface and retest connection.>
Here is the configuration file
!This is the running config of the router: 192.168.1.1
!version 12.3
hostname XXXXXX
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 XXXXXXXXXXXXX
enable password XXXXXXX
username XXXXXXXXX privilege 15 secret 5 XXXXXXXXXXXXXXXX.
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
dot11 network-map
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool sdm-pool1
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
lease infinite
ip ips po max-events 100
no ftp-server write-enable
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid CISCO ROUTER
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid CISCO ROUTER
authentication open
guest-mode
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 2
interface FastEthernet0
description $ETH-WAN$
ip address dhcp client-id FastEthernet0
no ip route-cache
speed auto
half-duplex
interface FastEthernet1
ip address dhcp client-id FastEthernet1
ip nat outside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
interface FastEthernet9
no ip address
interface Vlan1
no ip address
no ip route-cache
bridge-group 2
interface Async1
no ip address
no ip route-cache
interface BVI2
ip nat inside
no ip route-cache
ip classless
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface FastEthernet1 overload
access-list 1 remark INSIDE_IF=BVI2
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
bridge 2 protocol ieee
bridge 2 route ip
line con 0
line 1
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
privilege level 15
password XXXXXX
login local
transport input telnet ssh
end
Any ideas what my be the problem? thanks
Solved! Go to Solution.
08-26-2008 03:23 PM
Roger,
Try consoling into the router and add the "ip routing" command, Then give it another try.
HTH,
Mark
08-26-2008 03:23 PM
Roger,
HTH,
Mark
08-26-2008 04:25 PM
thanks that was it
