06-21-2006 09:24 AM - edited 03-03-2019 01:04 PM
hey,
im attempting a lab to allow dial-backup in the even of a primary link failure. it is working fine but i wanted to find out if there was a way to allow the backup connection to detect the link failure and automatically dial using the backup interface. for instance object tracking on the interface i desire
06-21-2006 11:55 AM
Try searching Cisco's website for the "Dialer Watch" configuration parameters. Here's a brief description. Should work similarly for ISDN or POTS backups.
http://www.cisco.com/warp/public/123/backup-main.html#dwatch
Rob
06-22-2006 11:08 AM
hey,
i have everything working so far. the issue now is that there is no consistency. i will get the automatic dialout when i down the primary interface, but when i connect the main interface again and bring it back down, the modem doesnt dial. debugs show that modem hangs up and is in idle state everytime
03:25:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
03:26:00: %LINK-3-UPDOWN: Interface Serial0/0, changed state to down
03:26:10: Se0/0 DDR: re-enable timeout
03:26:10: DDR: Dialer Watch: watch-group = 1
03:26:10: DDR: network 10.0.0.2/255.255.255.0 DOWN,
03:26:10: DDR: network 192.168.11.1/255.255.255.0 DOWN,
03:26:10: DDR: primary DOWN
03:26:10: Se0/0 DDR: Dialer Watch: resetting call in progress
03:26:10: Se0/0 DDR: Dialer Watch: Check reconnection needed
any ideas?
06-22-2006 01:44 PM
Sounds like the router portion is working as expected. Modems can be tricky. I've had similar problems in the past. Sounds like the modem is not configured properly. Perhaps it is not hanging up after it dials?
Does the modem dial and connect the first time that you down your primary connection? If it does, is it just that it fails the second time around?
Take a look at these modem AT codes which I found very helpful when I had to install dial up access:
http://support.microsoft.com/?kbid=164660
You may want to reset the modem to factory default before changing any settings.
Let me know...
Rob
06-23-2006 09:10 AM
i was thinking along the same lines as well, but,
the inconsistency is for the automatic failover with the dialer watch only. if i issue a ping to the remote end the modem dials through fine all the time.
my configuration has a dialer watch for the primary link ip with a delay of 4. i have a all forward route to the remote location.
very simple, but its just not consistent
06-28-2006 08:12 AM
Do you have a config?
I use this to dial into a 3640.
interface Async5
ip address 170.1.1.16 255.255.255.0
encapsulation ppp
keepalive 10
dialer in-band
dialer idle-timeout 300
dialer string 9,xxxxxxxxxxx
dialer-group 1
fair-queue 64 16 0
ppp authentication chap
