Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Extranet/ prefixlist
Hello
I have to configure extranets.
This has to be done for different routers(or subnets) belonging to 2 different vrf's.
Traffic from A to B has to be allowed and denied from B to A.
Could somebody advise me?
Thank you
Fred
Silver
Re: Extranet/ prefixlist
Hi Fred,
You can consider doing PAT or dynamic NAT from A to B . PAT will hide your network A .So no traffic can be sent to network A from B.
Saju
Pls rate helpful posts
Hall of Fame Super Silver
Hello Fred,
you can implement an MPLS VPN extranet solution to make communication possible between the two VRFs.
On each router belonging to VRF A you can accept TCP sessions only if already established
access-list 123 permit tcp x.x.x.x y.y.y.y any established
access-list 123 deny tcp x.x.x.x y.y.y.y any
access-list 123 permit ip any any
int gx/y
ip vrf forwarding VRF_A
ip access-group 123 out
where x.x.x.x represents the networks of VRF B.
the extranet solution is simply the adding of route-target import command within VRF interfaces
ip vrf VRF_A
route-target import
to be added
ip vrf VRF_B
route-target import
Hope to help
Giuseppe
111
