06-30-2014 03:39 AM - edited 03-04-2019 11:15 PM
I have a job on where I need to be able to use EZVPN with split tunnel but still have access to an external server from the corporate network as the external server will only accept connections from the corporate public IP address.
So I have not only included the corporate C class in the interesting traffic but also the IP address of the external server.
So all good so far, traffic for the corporate network goes down the tunnel as well as the IP address for the external server.
Now comes the problem, I am trying to send the public IP traffic for the external server out of the corporate network into the public internet but it just drops and does not get back out the same interface into the internet.
I checked out this procedure and it did not help as the route map counters do not increase with my attempt to reach the external router.
http://www.cisco.com/c/en/us/support/docs/security/vpn-client/71461-router-vpnclient-pi-stick.html
And to just test the process, I removed the split tunnel and just have everything going down the tunnel so I can test with any web site. I also have a home server on the network that is reached so I can definitly reach into the network at home which is the test for the corporate network I am trying to reach.
Its a cisco 870 router and here is the config
Router#sh run
Building configuration...
Current configuration : 4617 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 *************************
enable password *************************
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.1.3
ip dhcp excluded-address 192.168.1.4
ip dhcp excluded-address 192.168.1.5
ip dhcp excluded-address 192.168.1.6
ip dhcp excluded-address 192.168.1.7
ip dhcp excluded-address 192.168.1.8
ip dhcp excluded-address 192.168.1.9
ip dhcp excluded-address 192.168.1.111
ip dhcp pool myDhcp
network 192.168.1.0 255.255.255.0
dns-server 139.130.4.4
default-router 192.168.1.1
ip cef
ip inspect name myfw http
ip inspect name myfw https
ip inspect name myfw pop3
ip inspect name myfw esmtp
ip inspect name myfw imap
ip inspect name myfw ssh
ip inspect name myfw dns
ip inspect name myfw ftp
ip inspect name myfw icmp
ip inspect name myfw h323
ip inspect name myfw udp
ip inspect name myfw realaudio
ip inspect name myfw tftp
ip inspect name myfw vdolive
ip inspect name myfw streamworks
ip inspect name myfw rcmd
ip inspect name myfw isakmp
ip inspect name myfw tcp
ip name-server 139.130.4.4
username ************************* privilege 15 password 0 *************************
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group HomeFull
key *************************
dns 8.8.8.8 8.8.8.4
pool SDM_POOL_1
include-local-lan
netmask 255.255.255.0
crypto isakmp profile ciscocp-ike-profile-1
match identity group HomeFull
client authentication list ciscocp_vpn_xauth_ml_1
isakmp authorization list ciscocp_vpn_group_ml_1
client configuration address respond
virtual-template 3
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
set security-association idle-time 1740
set transform-set ESP-3DES-SHA
set isakmp-profile ciscocp-ike-profile-1
crypto ctcp port 10000
archive
log config
hidekeys
interface Loopback10
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description TimsInternet
ip flow ingress
ip policy route-map VPN-Client
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 3
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Virtual-Template3 type tunnel
ip unnumbered Dialer3
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect myfw in
ip nat inside
no ip route-cache cef
no ip route-cache
ip tcp adjust-mss 1372
no ip mroute-cache
hold-queue 100 out
interface Dialer0
no ip address
interface Dialer3
ip address negotiated
ip access-group blockall in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp header-compression
no ip mroute-cache
dialer pool 3
dialer-group 1
no cdp enable
ppp chap hostname *************************@direct.telstra.net
ppp chap password 0 *************************
ip local pool SDM_POOL_1 10.0.0.10 10.0.0.100
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer3
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 101 interface Dialer3 overload
ip access-list extended VPN-OUT
permit ip 10.0.0.0 0.0.0.255 any
ip access-list extended blockall
remark CCP_ACL Category=17
permit udp any any eq non500-isakmp
permit udp any any eq isakmp
permit esp any any
permit ahp any any
permit tcp any any eq 10000
deny ip any any
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map VPN-Client permit 10
match ip address VPN-OUT
set ip next-hop 10.0.0.2
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
scheduler max-task-time 5000
end
Router#exit
Connection closed by foreign host.
07-05-2014 11:13 AM
Hello.
I see you Virtual template interface is not enabled for NAT. So, NAT is not provided for spokes.
After you fix NAT, you will face an issue with CBAC, as traffic came from spokes is not inspected (ZBFW?)
07-14-2014 06:10 PM
Thanks for the response.
Not sure how that would help as I can connect into the internal network just fine, but I want to hairpin back out the interface and surf the internet from the VPN client. The policy route map makes the L10 the next hop and it has NAT.
