10-17-2009 11:45 AM - edited 03-04-2019 06:24 AM
What does it mean "fabric-enabled" in 6500 switches and how much
difference is it between a normal module and a fabric-enabled module
in terms of performance?
waitong your replies
regards
M.A.M
10-17-2009 12:39 PM
Hello Mohamed,
the C6500 architecture white paper is a very good document
in the C6500 coexist different types of forwarding plane facilities:
the older shared bus
the newer 256 GBps Exor 720 Gbps switching fabric
a fabric-enabled linecard can connect to a switching fabric.
CEF720 capable linecards can connect to 720 Gbps switching fabric that is present on Sup720 series supervisors.
older SFM modules provide a 256 Gbps switching fabric.
A shared bus is a bus that is only one communication can used it at the same time: if linecard x sends a frame to linecard y at the exact time t0 no other linecard can use the shared bus.
A switching matrix or fabric can be non blocking that is it allows for concurrent communcations between different linecards pairs.
An old linecard has a 8 Gbps connection to the shared bus.
A new linecard can have two 20 Gbps each connections to the switching fabric.
Hope to help
Giuseppe
10-17-2009 04:23 PM
Giuseppe's reference provides many details, but what a switch "fabric" normally provides is some type of cross bar architecuture that allows multiple points within the architecuture to communicate without sharing bandwidth. For example, port 1 can communicate with port 3, at full rate, while ports 2 and 4 do likewise (NB: fabric isn't always per port).
Within the 6500 architecture, many of the fabric capable cards support local forwarding decision making (with a DFC module) without involving the main chassis supervisor.
The two forging features support a very high aggregate processing and forwarding capacity compared to a 6500 using just "classic" line cards.
To contrast performance, a sup720 supports 15 or 30 Mpps and the shared classic bus 32 Gbps. The sup720 also provides a 720 Gbps fabric. CEF720 line cards, that support a DFC, the DFC supports 48 Mpps (this per each such card - about 400 Mpps for chassis).
