Community Member
Fail over on a 2801
I have two 2801 routers. One of the routers has a t1 wic. The outside t1 wic has an ip of 10.1.1.1 and the inside has and ip of 10.1.1.2
The second router is a vpn connection that will be used for redundency. The inside ip is 192.168.1.1 and the outside ip is 10.50.1.1
How can I set these up so if the t1 router or (circuit) goes down it will fail over to the vpn connection.
Orginaly i put static routes on the servers with metrics but that doesn't work unless the inside interface of the t1 router is down.
Thanks in advance
Community Member
Re: Fail over on a 2801
Anyone???
hi
you need to do a little bit of workaround by either going for HSRP or GLBP to have redundancy built in with the platform or load balancing between the 2 different platforms.
But in that case you would require to have both the routers inside interface on a single lan subnet so that you can achieve the same..
Wan (outside) part you can have simple /30 subnets configured between your locations..
Also throw more light on what kinda connectivity you have on the outside interfaces of the router...
regds
94
